Automatic gear fault
08.05.2020 20:03 # 1
Yusuf307
Friends have read the post in the forum, the masters I asked did not change, we open a samzimanci, we see, he says he can find the price 1500, he bought the car, I just bought the car 178 thousand myself, I am an electrician, a little bit of expression, the alternator tensioner is making a sound, there is tremor and steering hardness in the headlight. When it comes to half parts of 2 gears, it malfunctions. Is there a cheap place where I can get it done?
08.05.2020 20:03 # 2
erendumlu
Unfortunately, you do not have the chance to go cheap with automatic transmission. Since it is much more complicated and risky in terms of workmanship, it is normal for them to ask for those money.
The important thing is to master which master, rather than the fee. I would definitely open it to someone who had worked in the authorized service and had trained those gearboxes.
08.05.2020 20:03 # 3
Yusuf307
When I get it going for a long time, we will get it done, but I don't know why, for the first time in my life, I was buying an automatic and Peugeot. there is a lot of pressure, the clamp is slipping back, there is a bit of wet fear
08.05.2020 20:03 # 4
erendumlu
If there is swelling in the upper hose, the vehicle is missing the engine compression into the water system. It can make it from the lid, it can either be made from the gasket or even from the block. The cover should be opened and checked at the recipient.
There is a possibility that the radiator is blocked, but there is an easy way to understand it. Let the vehicle run until the fan turns on. Touch the bottom of the radiator after the fan stops. If it is cold, the radiator will change. No, if it's hot enough to touch. The upper part is always warmer than the lower part. Don't compare it.
Unfortunately, the transmission issue has nothing to do with the engine.
Did you connect the pp2000 to the engine malfunction lamp that you said is giving malfunction and have looked at where the malfunction is from? Maybe the transmission is ok, the whole problem is on the engine
08.05.2020 20:03 # 5
Yusuf307
The top cover has already been repaired, they have already closed with a steel liquid gasket. The temperature is only 100 in traffic. When the fan turns on, it falls down when I turn on the fan. I am not stuck on the long road. I am a stranger to the Peugeot. I saw the water when I think it comes to the oil pressure failure and protects it, then it stops when it stops and works, but only in the cold in the first run in the morning
08.05.2020 20:03 # 6
talip206
The transmission problem probably seems to be solved by oil change and solenoid replacement. Do not believe that the gearbox should be opened immediately. Even a lack of fat can lead to this problem. By the way, the temperature values you mentioned are normal. It is normal to have 90 to 100 in traffic.
08.05.2020 20:03 # 7
Yusuf307
Thank you, I will meet you in the sharing of information,
08.05.2020 20:03 # 8
Marcello
Slm same problem is also available in my vehicle automatic geard foul Do you have a good transmission that you can recommend in Anatolian side?
08.05.2020 20:03 # 9
ahmettartan
I changed the solenoids, there was the same error I am not getting anymore thank god ... kept around 1500tl
