Automatic Gear Fault
08.05.2020 18:09 # 1
MertMurat
A lot has been written about this subject in 307 but nobody has reached a clear solution
those who usually get this problem are those who install lpg
I bought the vehicle in 110 thousand before I wrote it 100 thousand lpg fitted in 112 thousand I changed gearbox oil for the first time, the man I bought never changed this I wrote before
After the oil change 3 times, I got on 10000 km smoothly and started to repeat today and I paid attention to this, it never gives this fault when going on gasoline
When lpg is in and lpg is decreasing, it often gives this error when I stop the lpg and when I turn off the LPG, this problem does not give a long time.
Now, like some of my friends, I want to change solenoid valves, I want to change them and change the transmission oil.
you asked the service to the one said 238 TL
I searched from the net 105 TL this imbalance boyle diamond auto is trying to do boyle
After changing these solenoids, I am thinking of removing them from the LPG.
08.05.2020 18:09 # 2
mami202
You are right, there are a lot of subject and comment experience. The lpg automatic transmission is not good for the vehicle that I have not been able to look at the lpg event (it is my personal opinion is all about feeling)
Since the transmission brain has a structure that evaluates all the data received from the vehicle and the user and reacts accordingly, the most important factor affecting the regular operation of the transmission in LPG.
Let's come to the error event
normally the authorized services say that the oil of automatic transmissions do not change for life
They say special services must change max 40 thousand.
so what are we going to do? my personal opinion is that if we are the first owner of a vehicle with an automatic transmission, I think it would be beneficial to renew an average transmission oil of 30 thousand without disruption.
If we have a vehicle whose transmission oil has not changed to this day, there is nothing left to do.
unfortunately, the gearbox is unfortunately resolved in the short term with solenoid and oil changes, and we can say that it is like using a pain medication.
I recommend you connect your vehicle to a computer with a good gearbox, see the data about the gearbox and act accordingly.
08.05.2020 18:09 # 3
MertMurat
Look, I experienced so much yesterday, it was the same again, LPG was over.
this time the situation was very different, it didn't work even in the snow mode. I went to the gas station in the snow mode.
but unfortunately there is no good master I know
08.05.2020 18:09 # 4
mami202
Get well, when you decide to take a look at the gearbox, if you want a suggestion, I can recommend the place that makes the transmission of my vehicle.
08.05.2020 18:09 # 5
metin
It has absolutely nothing to do with LPG. If it fails with LPG, it gives "antipollition foult" error, which is because it cannot measure the air fuel mixture since the oxygen sensor is disabled.
Al4s have certain trial methods. monur brothers would have it.
There may be various problems, from putting too much oil or wrong oil to throwing the wrong software. including abuse. First of all, to reach the cause of the problem, it is necessary to lift the vehicle on the slope and put it into tests.
08.05.2020 18:09 # 6
MertMurat
This issue is resolved
I http://forum.peugeotturkey.com/forum_posts.asp?tıd=33091&title=nihayet-cozul
