Automatic Gear Fault
08.05.2020 17:46 # 1
hakana
After automatic gear fault warning, suddenly it falls from 4th gear to 3, and it is only 3rd gear including stop and start until stop and restart, I want to benefit from the experience of those who have experience in this matter.
08.05.2020 17:46 # 2
Haksen016
Hi ,
this error is primarily the transmission malfunction. There may be 2 reasons.
Transmission oil, the first of which has completed its life, is no longer functioning. Do not believe transmission oil is lifetime.
The second is the malfunction of the cellonoid valves that control the oil pressure inside the gearbox. in this case, valve replacement will correct the malfunction.
As someone who has experienced this problem for a long time, after changing the oil first, if the problem still continues, it is the cellonoid valve change.
I changed my oil first, it was a short solution, then I changed the valves. I don't have any trouble right now.
I hope I could help.
08.05.2020 17:46 # 3
hakana
thanks
08.05.2020 17:46 # 4
hakana
I am thinking of changing the steering wheel, let me know if you have any
08.05.2020 17:46 # 5
night_blue_2229
brother, I have the same problem, the car gives a gear fault error when the car is loaded on a little ramp or a lot of gas. They said that it is not a mistake to use it in snow mode, but it gives the same error in snow mode. what can I do? Is there any master you would recommend, thank you in advance. if solenoid and oil change, I will also report the result I am thinking of going on Tuesday.
08.05.2020 17:46 # 6
EnSoNiQ
It would be wrong to do something without changing the solenoid and oil, but I got the same error 1 times. I changed my solenoid valves.
08.05.2020 17:46 # 7
night_blue_2229
I understand, well, did you have a chance to try it on the long road after the change? The car gets into 3rd gear protection mode and it gets cumbersome. it does not pass to manual. You will use trouble-free construction without incident.
08.05.2020 17:46 # 8
hakana
exactly, the vehicle only stays in 3rd gear but it started to do so many times in the past, it used to do it once a day, 3/4 km going on and off, the contact would be improved, but whatever I do, I do not pay any money ..
08.05.2020 17:46 # 9
night_blue_2229
brother, I changed it, I was very pleased, I started to enjoy the car, 500 lira costs out, solenoid and oil changed, I made it in the maslak.
08.05.2020 17:46 # 10
hakana
Thanks, I made it in Florya yesterday, it cost 450 TL, what anguish we have suffered
08.05.2020 17:46 # 11
hakana
Oh, otherwise, I'm glad early. solenoid and oil changed, but again the same warning I stop and run at least three times but it gets better ... any information about this subject .... OuchOuch
08.05.2020 17:46 # 12
msertkol
I had it, I stopped working for a while. But it will not be looked, I went and got it. Valves and oil changed, software updated. I used it for 3-4 months, after 1-2 thousand km, the same thing got worse. It started to malfunction more frequently.
Now I put it on my heart, I opened the gearbox, I am waiting for the result. The car has been in the master for 9 days. It is just collecting. Bushes and turbines are worn inside. He repaired it, we will collect it, but we did not talk in detail. Let's see what account I am waiting with curiosity.
If I knew, the car would take me 50000km, I am grateful for the money I gave.
But will I pay like this every year? I did not understand him. Also, I can not resist selling the car very comfortably. How many times have I taken pictures but I could not put it on the advertisement ...
I like the sound of the engine separately, I like the interior, the windows, the stance separately ..
But just because of this automatic gear fault, I will not cool from my car.
I believe it is a good car.
Best regards..
08.05.2020 17:46 # 13
hakana
When your sanjiman meets, let me know, then let us see how they ask 2000 how to find the cost.
08.05.2020 17:46 # 14
hakana
I would like to change your sentiment completely, I would appreciate it if anyone wants to share their suggestions and experiences
