Automatic Gear Fault
05.02.2021 15:36 # 1
mirz.11
Hello friends. When I shift the car from P or N mode into gear, it switches with 2-3 seconds delay and gives this error. There is also the sound of locking the gear when starting or closing this car and it starts to do it when I press the brake and accelerator while constantly in gear. But not every once in a while, he makes this gear noise constantly. It never goes to the manual anyway. I read the other subjects here. We installed the computer in the service, changed the oil, other masters looked, but nobody says anything definite. I got the error 2-3 months ago, it disappeared and came again. I'm really sick of this error.
06.02.2021 16:08 # 2
muzzy35
My teacher, I suggest in a completely amateur way, let me tell you from the beginning, the clicked sound of the vehicle only unlocks and lowers the gear lock when I press the brake, so I suggest changing the brake light at first cheap first change it, you look it works
08.02.2021 00:31 # 3
talip206
Have the brake switch and gear position switch checked. In addition, if you connect your vehicle to an original peugeot device, you are likely to find a pinpoint problem.
08.02.2021 14:04 # 4
mirz.11
Well I'll change it as soon as possible. I wonder if it's a possible situation to give this error because of the brake switch?
