Automatic Gear Fault?
08.05.2020 15:11 # 1
Ako06
While my friends were driving, this article came out a few times `` Automatic Gear Fault '' and come out 1 - 2 sec. then it passes. . with knowledge?
08.05.2020 15:11 # 2
[QUOTE = Ako06] This article came out several times while friends were driving, `` Automatic Gear Fault '' came out for 1 - 2 seconds. then it passes. . with knowledge? [/ QUOTE]
The transmission starts from the oil and goes up to the valves and then to the hydraulic block. It is useful to find a good master and make him look.
08.05.2020 15:11 # 3
Ako06
thanks.
08.05.2020 15:11 # 4
Ako06
I say for your friends. we have the vehicle connected to the machine. saw the problem. Then he said that there was a malfunction in the brain and he dealt with it, and I deleted the pain in the brain. use a little like this, if the problem arises, the valves will change. One 180 TL.
08.05.2020 15:11 # 5
oguzhan29
Don't be fooled by the price that a master says, if you have your own master, go to the part research you know, buy it cheaply and get it done, you don't need to have it done in the service.
08.05.2020 15:11 # 6
metin
the price is good, i will change the valves + transmission oil next week i got 450 tl price.
By the way, for those who do not know, solenoid valves are two pieces.
08.05.2020 15:11 # 7
Ako06
I already bought this price from my own master. I guess the price is already around this place. Oh, by the way. The man said to use it for a while and after a few days he gave the error again. I haven't had much to try, but I think 4. does not change gear. automatic transmission, the speed is up to 4 thousand vehicles shout, the gear does not change.
08.05.2020 15:11 # 8
mimitt
The valve but which valve, solenoid valves are mentioned, I think the price is expensive. I bought it for 135 TL for 406 al4 gearbox.
08.05.2020 15:11 # 9
metin
[QUOTE = Ako06] I already bought this price from my own master. I guess the price is already around this place. Oh, by the way. The man said to use it for a while and after a few days he gave the error again. I haven't had much to try, but I think 4. does not change gear. automatic transmission, the speed is up to 4 thousand vehicles shout, the gear does not change. [/ QUOTE]
the constants do not drop to 4 in the 3rd gear so that you can go to the service when it fails. My master had said in such cases, take it to snow mode and take it to where you go
08.05.2020 15:11 # 10
Ako06
thanks .. We are talking about @Mimitt solenoid valves. But I researched quite a lot, the price is around this. for pug 307.
08.05.2020 15:11 # 11
mimitt
solenoid valve okay, your vehicle has 4 or 5 valves separately for the gears and there are two main large valves. They are the fastest breaking big valves, the original of which is around 135 TL in Ankara particles.
08.05.2020 15:11 # 12
Ako06
There must be big valves .. I knew 2 pieces. already said 2 master should change .. our master said 180. Where can I find cheaper? Is there a place to recommend?
08.05.2020 15:11 # 13
ismail ozdemir
either the same post came out of me yesterday and even though the gear is d when it stops, i can feel the car getting out of the ground and when i release the brake it does not progress as long as i do not press the gas and also it goes back on the yoke
08.05.2020 15:11 # 14
Haksen016
I had the same problem in me, I first changed the gearbox oil for 1.5 years, no problem, thank goodness, but if you say relax, the cellonoids + oil change will be the solution.
08.05.2020 15:11 # 15
ismail ozdemir
Did you have the same problem when the vehicle stopped?
