automatic gear but stops ..
08.05.2020 20:17 # 1
akyuz.cagri
Friends, I use the 2000 model automatic gear. output??
08.05.2020 20:17 # 2
My teacher is not a shaman, have the starter dynamo checked and how is the battery condition.
08.05.2020 20:17 # 3
eng uzn
I have the same problem .arac lpg limi. Do you stop when you go on gas
08.05.2020 20:17 # 4
talip206
[QUOTE = akyuz.cagri] Friends, I use 2000 model automatic gear. 2000 km ago changed, this run is new ?? [/ QUOTE]
Is your first automatic vehicle. In another gear other than N and P gears, the vehicle will not operate as if the battery is dead. This is for security. It only works on N and P. If it does not work even though n and p are other than that, the shift position switch may be a problem.
I also had a stop event, I told the lpg player, it adjusted and it improved. If it always stops at lpg, it is related to lpg setting. talip206 2017-04-05 20:07:42
08.05.2020 20:17 # 5
akyuz.cagri
no lpg in the vehicle ... no battery or trouble .... it plays a little with the gear ... I pay attention to leave the car in n or p ... I don't think it should be from it but a little more attention to it ....
08.05.2020 20:17 # 6
Brake sensor change teacher
