automatic gear 206 stops?
08.05.2020 18:22 # 1
pejo34
Hello friends
2000 model pejo 206 have gasoline
My vehicle is not driving, when I stop the lights at the street exits
suddenly it stops, the steering hardens and the brakes harden,
Sometimes it never happens, sometimes it happens very often.
Although it is very rare, it stops when I put it in reverse gear.
throat butterfly cleared - transmission oil changed problem continues.
I get gas from wherever it comes from, I may be related to it
throat throttle cleaned - transmission fluid changed
08.05.2020 18:22 # 2
tetik-soner
I was also changing the idle valve there was no problem.
08.05.2020 18:22 # 3
pejo34
[QUOTE = trigger-soner] was happening to me I changed the idle valve, no problem. [/ QUOTE]
idle valve cleared but the fault still continues, not always stop
Thanks for the information you provided,
08.05.2020 18:22 # 4
realemperor
There is a reason for it, if there is a shake in the light when it stops in the light, otherwise it may be from the speed sensor, connect it to the device.
08.05.2020 18:22 # 5
pejo34
he does not eat gas 2-3 seconds before stopping and stops suddenly.
08.05.2020 18:22 # 6
tetik-soner
I cleaned the idle too ... the next day he did it again ... I ordered it, I put it on my own ...
08.05.2020 18:22 # 7
Serkan
I experienced the same problem for whatever problem you mentioned, but my problem is solved with lpg settings, I think you don't have lpg.
08.05.2020 18:22 # 8
pejo34
[QUOTE = Serkan] For whatever problem you mentioned, I had the same problem but my problem is solved with lpg settings, I think you don't have lpg. [/ QUOTE]
no lpg.
08.05.2020 18:22 # 9
fahrettin
I live in a similar situation in 1998 model 306. gas adjustment, butterfly cleaning, valve adjustment is still underway. I suspect idling engine like trigger-soner
http://forum.peugeotturkey.com/forum_posts.asp?tıd=34090&title=306-istop-sor the
