Automatic 307 ramp does not shift !!!
08.05.2020 18:02 # 1
hater
Friends everyone mrb. I did a lot of research in the forum but I couldn't find the answer to my problem exactly, so I had to open a new topic ...
Let me come to my problem : I have a 2005 model automatic 307 xt premium vehicle. At 97000km. The vehicle does not cause any problems when driving on a straight road. But for example, when driving from Aydın to Konya, there is no problem on the straight road for 300-400 km, but when a steep and long ramp comes, the gear shifts from 4 to 3 and the gear does not increase again. I mean, even if I take the manual, the D position appears on the screen. As I cut my speed, the gear drops to 1, but it does not come out definitely. They said it does not appear. What way should I follow? I would be glad if you helped the problem. Thank you for your help in advance. By the way, I live in Aydin. Good day.
08.05.2020 18:02 # 2
mami202
I got stuck in 3rd gear
Regardless of the ramp or straightness, 120- 130 km speeds, while driving in 4th gear, make a dipgas and automatically take the gear to 3, and when the speed reaches 4-5 thousand, the mounted pattern fails. Try something like this, when the vehicle is in 3rd gear and takes over and takes it to 4th gear, you take your foot off the gas and make the gearbox shift as if using a clutch vehicle and press the gas pedal again.
I did not change the oil - valve change maybe because it would be improved.
mami202 2013-11-03 19:09:52
08.05.2020 18:02 # 3
hater
Thank you, my friend, but I wonder if my problem is with an electric valve. I remained undecided. Also I did not try the method of pulling the foot out of the gas you said. In other words, I have to stop the vehicle.
08.05.2020 18:02 # 4
berk2309
My teacher test method, then go to the computer and connect to the computer, measure the pressure of the valves, or valve accordingly. it does so because it gets too hot while the ramp is going out, it also makes it from the end of the band assembly or it makes the torque converter fail.
08.05.2020 18:02 # 5
hater
We have connected it to the computer, there was no malfunction, brother.
08.05.2020 18:02 # 6
serhat79
hater brother same problem we could not solve in my car at the moment.
