Automatic 307 oil selection
08.05.2020 15:10 # 1
Hello,
I had an oil change last month. They put a total of 10-40 semi-synthetics, but a strange increase in sound in the car. Before the engine oil warms up, it sounds like a valve knock. At first I thought lpg was coming from the injectors, but then I realized that it is not. It comes from a part of the engine. I asked the master, said the cup (!). They said the valve pusher is a cup :) he can not get oil into it, he makes a sound from him. I asked the oil, what do you use? I said 10-40 semi-synthetic. He should have a look at his guide, maybe the oil feels thick, he said. This day I stopped by. We put 0-30 CASTROL_EDGE 4lt oil. As if the sound was cut off a little bit but time will show. It can also be psychological.
Essentially I want to ask this. We put 0-30, but did we mistake Gülme Let's not damage the engine while stopping. I don't understand much, but they said it was better. If it is wrong, those who say it will not be there when I embrace the engine.
08.05.2020 15:10 # 2
It's not a mistake. I use Mobil 1 0W-40 and, as you said, my car works quieter and without a beat compared to the previous one. 0W-30 is definitely not a fault. I would say it is a more accurate choice compared to 10W-40.
08.05.2020 15:10 # 3
BAHTIYAR
I have the same problem, when the valve thrusters are in idle, especially when it is cold, it makes sound like click-to-injector sound, if you root and release the gas, it gets better and it doesn't get hot. )
08.05.2020 15:10 # 4
[QUOTE = BAHTİYAR] I have the same problem, when the valve thrusters are in idle, especially when it is cold, it makes a sound similar to the injector sound when it is cold. there are 50 pieces of lira:) [/ QUOTE]
hınggg Confused
the nasiii Embarrassed
50 of them? no mistake? 800 pounds just valve pusher + labor put 1,000 pounds so Ağlama
the cover 2011-03-19 22:47:59
08.05.2020 15:10 # 5
BAHTIYAR
Exactly, brother, no tampering, try to reduce the boron power a little bit after I bought the car, it came out 3 months later, but I got used to it, but the boron was good too, not a problem. We were 60 mobile 1
08.05.2020 15:10 # 6
muhammedyksl
Hello friends, when I read the writings here, as soon as I get my car, the first job was to change oil. Whatever comes to your mind from the last crankshaft pulley, I went to a master, asked me the oil change card and said that they put the wrong oil 10-40, they said 5-30, if we put it in 5-30, the problem would be solved anyway. Is there any oil that you can suggest? They said mobile 1 5-30, but I did not know, they talked about the cups in the meantime, but I would be glad if you answer the car if there is no harm ...
08.05.2020 15:10 # 7
metin
they put me a total of 5-30 fats, I have no trouble, I'm glad.
08.05.2020 15:10 # 8
alisuat
5 40 can be mobile.
08.05.2020 15:10 # 9
ramtas
Put the engine internal cleaner into the old oil without changing the oil, especially put the wurt brand, then run it for 15 minutes and then pour it to the new oil. Also, the gasoline additive in the oil is reduced to a minimum for the injectors.
08.05.2020 15:10 # 10
muhammedyksl
Hello friends, I changed the oil of my car, I made the oil change, I wanted to share my experiences, I mentioned my previous troubles above. I could not get the exact result I expected. What can be done? Let's change the cup or cup of it.
08.05.2020 15:10 # 11
kudret_yildirim
at least 25 km to show the effect of boron power. I know you have to make way. The film layer is formed in the first 25 km, after the first 400 km, the formation is completed and starts to show its full efficiency.
