Automatic 307 issue
08.05.2020 21:31 # 1
206arts
Automatic gear 307 when the temperature exceeds 90 95
Only in 1st gear, the vehicle is wasted and when it gives off gas, it knocks it into 1st gear.
Other gears transitions are excellent.
When I just slow down and stop falling from 2 to 1, it is wasted
Have knowledge
08.05.2020 21:31 # 2
First of all, the fault codes should be checked with the software, hodja. can be a simple problem. the brake sensor can be effective in this type of problem.
08.05.2020 21:31 # 3
EmSul
I did a lot of trouble with the same problem last summer, brake brake is not something, gearbox intervention is required, but the gearbox does not come down, no revision is in the solution, automatic transmission, contact with the camil master, he is solving, do not tamper with someone else, do not even change the oil, I would give the number of the camil master if you want to tell me
08.05.2020 21:31 # 4
KILIC
The transmission oil cooler may not be working.
08.05.2020 09:19 # 5
206arts
[QUOTE = EmSul] I did a lot of trouble with the same problem last summer, the brake sensor is not something. city
08.05.2020 23:20 # 6
muzzy35
If you are close to Sakarya, I can recommend a master.
09.05.2020 18:38 # 7
EmSul
kamil master in the shop in bursa but there are shops in ankara and yalova
27.07.2021 13:30 # 8
ralf_fb
Hello , my vehicle is 2004 307 automatic LPG , in 2014 a friend asked what is the use of the following part in the forum , it has been 4 years since I bought the vehicle , the vehicle has not been working in P for the last 1 year. For example, when I stop at traffic or lights, when I take my foot off the brake, the vehicle does not start, it makes a loud noise as if someone hit it from behind, and then it takes off. When I asked the masters about this situation, they talked about many different reasons. I got out, the vehicle stopped working in N anymore and I stayed on the road. While playing with the gear, it worked by chance and then when I pushed the gear somewhere between N and R, I figured out that it worked. In this case, I finished my work and went back to Istanbul, after talking to a few transmission specialists, I found out that it was caused by the part in the link. I learned that after going to a peugeot electronics and replacing the part, both the non-working condition and the lights The problem that occurs as if it doesn't eat gas when it stops and someone hits it from the back has disappeared. I have used the vehicle many times in July and August for 1 month, I did not have any problems, I added it here as it may be useful for others.
By the way, the adjustment of this part called automatic gear contactor or position switch was done as follows. For additional information, if you come across a master who does not know his job, you can teach it, the gear should stay in N position after the vehicle is stopped, the part After the replacement is done, there are 2 tips on the part and the probes of the measuring instrument are connected to each of them and they are put into the BEEP sound mode. they adjust it by moving it from its place. p://www.peugeotmarket.com/PEUGEOT-307-OTOMVITES-K ONTAKTOR-SALTER,PR-2425.html" target="_blank" rel="nofollow">http://www.peugeotmarket. com/PEUGEOT-307-OTOMVITES-KONTAKTOR-SALTER,PR-2425.html
27.07.2021 13:49 # 9
muzzy35
Thank you for sharing, brother, you did not hesitate to write, God bless you, if it is left to the masters, it will make revisions, this information will save many people from that trouble...
