automatic 307
08.05.2020 21:21 # 1
mrt1986
Hello friends. When my 2004 automatic 307 vehicle is in reverse gear only until the engine temperature is about 70 when the engine is cold, everything is normal for 2 seconds. Then, with a sudden backward accumulation, the vehicle falls to cat speed Smile no matter how fast you press the gas, the acceleration does not accelerate, but the gas rises to 3 thousand revolutions, but there is no problem when the engine is hot. I always park the car back and forth from this problem Smile I wonder if anyone has an idea Confused
08.05.2020 21:21 # 2
erty1287
I went to the services in Ankara to change the transmission oil of my 307 sw automatic vehicle. If it changes, it may malfunction, valve adjustment, etc. 4 5 is afraid to change oil in 5 places. I have an al4 dpo automatic transmission in 307 sw and Citroën renault. I do not understand how much this document is contradicting, it is absurd to say lifetime
Does anyone have knowledge and experience in this matter thank you in advance
08.05.2020 21:21 # 3
murattgr
Yes, most places say so, if you change the spinal cord, so it is. I have changed simsiuah and missing cuts. Be sure the gear shift was noticeably nicer. Those who do not want to do do not want to enter because they cannot do this or if something happens afterwards. I can help you change oil if you are in ankrada
08.05.2020 21:21 # 4
Unfortunately, many of our oil industry tradesmen do not open the internet and do research or look at the technical documents as our friend says. If it does not change for a long time and then replaces it, it can dissolve deposits in the new gearbox, which can cause solenoid valves in the gearbox to be desired. Unfortunately, it is really difficult to find a master who knows his job well.
