Auto6r gearbox info see those
18.10.2020 21:05 # 1
aslan_308
Hello friends, I bought my 2011 model 308 4 months ago, today I had the chance to join you. My car has an Auto6r transmission and I want to change this transmission oil. I don't know if the owner before me changed, so I want to secure my job. My vehicle is at 170.000 km.Which oil does it use for this gearbox, does the oil change cause any malfunctions, what are the suggestions that people using this gearbox can give me for correct use? I will use the oil specified in the booklet for the engine oil, but there is no information for the transmission oil. Good forums to everyone.
19.10.2020 09:34 # 2
Hello my teacher. I wish you good luck with your vehicle. Changing the luckum oil is not a problem.
19.10.2020 19:53 # 3
aslan_308
Thank you. I know it is a special oil produced for Elf brand Renault. Will the oil you show me on my vehicle be suitable? I was looking for the oil in this link https://www.hepsiburada.com/total-75w80-gear-8-transmission-yagi-1-litre-pm-HB00000KVUVM. I wonder if this oil is suitable, there is also a mobil brand, but I don't know which one is better to buy.
19.10.2020 21:30 # 4
aslan_308
And the price was too high for me. How many liters will I have to buy from this? Do I have a cheaper alternative or should it definitely be this?
20.10.2020 09:23 # 5
My teacher produces total oil in that oil, no problem. Elf and total are filled in the same factory and put on the market. Do not look at the dry, sir, there is a separate oil for both the actuator and the gearbox in your gearboxes. oil of the actioner I sent me. The oil of the gearbox you sent is no problem.
20.10.2020 20:14 # 6
aslan_308
ok then I'll buy both. Well, how many liters should I buy from which one do you have any information?
21.10.2020 09:18 # 7
I don't remember him, sir. but usually the gearbox takes about 3 liters. 1 liter will probably be enough for the actioner.
