auto wiper fault
08.05.2020 18:18 # 1
cavit cevo
greetings
anyone know how to fix auto wiper fault error in rain sensor?
08.05.2020 18:18 # 2
cavit cevo
Hello
I guess everyone's rain sensor is working right?
08.05.2020 18:18 # 3
Serkan
[QUOTE = cavit cevo] hi
I have never heard of the warning in the forum so far, sensor troubles are often caused by the gel of the sensor in the glass.
08.05.2020 18:18 # 4
cavit cevo
Will the sensor change, so what is your opinion, brother?
08.05.2020 18:18 # 5
Serkan
If the distress is gel, only gel can be put, but the gel is only possible, if you can connect it to the computer, maybe you can learn the problem.
Unfortunately, if you had a friend problem in the link below but did not write the solution, take a look.
Link
08.05.2020 18:18 # 6
rzsrht
My teacher was also coming sometime. This mistake was corrected by himself. now it is active when you lift the arm up, the screen says it is active but it works continuously even if it doesn't rain. and when I was at normal speed 1-2 seconds later, even though I never played with the arm, it accelerates like I got to the last level .. I wonder if anyone happened to it .. I couldn't solve ..
08.05.2020 18:18 # 7
emirhan307
Cut it out of the gel, it was like this in my father's press.
08.05.2020 18:18 # 8
kuscu38
Either the sensor, or something related to the eye, there is no other part, but normally I can not say how it will work. So my sensor malfunction lamp is just on, or is there a problem with the sensor?
08.05.2020 18:18 # 9
cavit cevo
hi, it says auto wiper fault on the screen, the wipers are working, the glass changed sensor is removed and installed
I cleaned the cables but the problem still continues
08.05.2020 18:18 # 10
kuscu38
When I say the problem, the warning lamp continues to write, as I understand the others, there is no problem !!!
08.05.2020 18:18 # 11
cavit cevo
yes, it says auto wiper fault on the screen and then it goes on every operation
