Auto transmission or engine failure
08.05.2020 21:26 # 1
Murat.ari.206
hello my friends
1. I have a 206 xt otm gearbox, the gearbox was knocking, I changed the solenoids, but now I have another problem while I am driving, the km indicator is moving up and down, I go with 100, the pointer is instantly 50 to 50, in the meantime, it is 100. There is no fluctuation in km indicator when it does not press the gas, but as I said it deflects the pressure to the gas, it reduces the traction
2. When I proceed with the sudden situation, I suddenly press the gas, gas is not gone, I pull it to the right after 2500 cycles, I do not eat any gas, I press the gas, the speed is fixed at 1200, then I turn the ignition off and on, I start eating gas, the car moves up to 3000 rpm, but it turns out to be on the bus as if it is drowned, I make full throttle. I'm going to speed up, I'll be crazy
08.05.2020 21:26 # 2
talip206
It doesn't look like a transmission related situation. Your problem is most likely electrical. First, measure the battery and charger while in motion. Find out if the problem is cold or hot or not. If the problem starts when it is hot, there may also be a problem with the brain.
08.05.2020 21:26 # 3
Murat.ari.206
the problem starts when it is hot I got it connected to the device today transmission transmission error gave throttle error and brain error
08.05.2020 21:26 # 4
Have your sockets and throttle cleaned, sir. it would be better if you add error codes, we can make more healthy comments.
08.05.2020 21:26 # 5
Murat.ari.206
I deleted the errors, I will go and reconnect for 1 week then I will throw out the error codes
08.05.2020 21:26 # 6
In addition, when I say the brain or the engine ecu error room is important my brother Murat.
08.05.2020 21:26 # 7
Murat.ari.206
the friend who deleted it before seeing the error codes gave the throttle error, we only cleaned the throttle and its sockets in a week's use without brain failure.
08.05.2020 21:26 # 8
hknzed
Did you get automatic gear fault error on the screen?
