auto-mounted at 307P in the morning
08.05.2020 16:12 # 1
good morning friends
I went down every day in the morning, I started the car, I waited for a while for lubrication, then I tried to get the car out of P, but the car did not come out. It was stuck in 3rd gear, it was fixed by stopping and running again. It is no fault. It is 3 4 days. -10-05 08:05:28
08.05.2020 16:12 # 2
Most likely your brake sensor is malfunctioning. So when your brakes are pressed, your vehicle should get out of P. When the sensor is faulty, the vehicle locks automatically for a while when P waits for a while, and you should be able to open it by pressing the brake, when the client is faulty. It moves when it stops and starts. Moreover, this brake sensor prevents the speed stabilizer from being mounted and promoted, as well as causing the knocks you mentioned and causes an abs error when connected to the device. The solution is likely to be in brake sensor. You can put the cost into the service, like 20 TL economically ... hakangumus 2011-10-05 08:37:13
08.05.2020 16:12 # 3
I guess it looks like the gearbox path seems to have passed.
08.05.2020 16:12 # 4
metin
the brake switch is absolutely defective. it even affects the abnormal operation of the transmission, 20 TL something can be changed immediately get original.
& nbsp;
Steady with experience!
08.05.2020 16:12 # 5
alisuat
You have to replace it. It has been proven that the 20-piece piece is even affecting the way the vehicle is ordered. In this forum, you can even install it yourself.
08.05.2020 16:12 # 6
There was a section on the forum with information on how to clean the brake sensor. I looked from there, took the sender and changed it myself. You can change it too. You can do this if your hand is slightly prone to this type of work. still, it is good to be careful.
08.05.2020 16:12 # 7
my hand is inclined then I will change it myself, I explained the situation in the service, whatever the men say in the service, let's take a look and remove it :) Before I disassemble it, change a oil, adjust it, let's use it, they said to him that the gearbox mount does not change, oil life and what setting it is, the oil will not be discharged from the top. They said that there is no setting for new oil or something :) Yahu these guys will make me crazy, how can I order friends from the sponsor section?
08.05.2020 16:12 # 8
Mehach
You didn't forget to apply the brake, right? Could it be .. "Shocked" Mehach 2011-10- 05 14:30:44
08.05.2020 16:12 # 9
No teacher, I applied the brakes and I came home right now. I came to normal service to work, I did not have any trouble there. I wait a bit to let the car lubricate in the morning, before he moves, he will probably lock it at that moment. I could not find in the forum, let me find out how the brake sensor changed.
08.05.2020 16:12 # 10
metin
hawk call peugeot murat brother, credit card transfer etc. If you are in a central location, you will get your business immediately, you will get the next day.
is very simple to change. You unplug the socket of the customer on the brake, then you turn the leaflet halfway and pull it out. you are wearing the new one in the opposite way and you are going bye.
& nbsp;
was sometimes not leaving p in the morning when my client was broken. In addition, the elongation of gear shifts had started cumbersome on the vehicle. I still can't make sense, but when I and a few friends changed this, the transmission improved (:
08.05.2020 16:12 # 11
alisuat
08.05.2020 16:12 # 12
my alisuat teacher everything is written here thank you, text thanks i order now.
08.05.2020 16:12 # 13
metin
[QUOTE = htasay] my alisuat teacher everything is written here thank you, text thank you now order now.
08.05.2020 16:12 # 14
I said :) I placed the order thanks
08.05.2020 16:12 # 15
metin
[QUOTE = htasay] I said :) I placed the order thanks [/ QUOTE]
& nbsp;
see when it comes, check the gear changes, does it change from 3000 to 3300-3400,
& nbsp;
at a constant speed when he pulls his foot out of the gas, the speed falls suddenly with the compressor, look at them. Let's see if all of these troubles finally went to the brake sensor (:
08.05.2020 16:12 # 16
tolga35
text bro my brother is right the problem is in the customer. my p was not locking at all, the gear was knocked off and the vehicle was cumbersome.
08.05.2020 16:12 # 17
metin
[QUOTE = tolga35] text bro my brother is right, the problem is in mine. My p didn't lock it at all, the gear was passing and the vehicle was cumbersome. I said the text, i still listened to him to take a thank you ... [/ QUOTE]
& nbsp;
God bless you, I always thank my brothers and sisters I learned, they did not say that they multiply as they share information "Laugh"
08.05.2020 16:12 # 18
My teacher started the fall of this tachometer with the last two problems, let's take the car for 3 weeks or so. We used it smoothly until the end of last week but it started to malfunction last week. :)
htasay 2011-10-05 16:42:38
08.05.2020 16:12 # 19
Long Beach
[QUOTE = htasay] my hand is inclined, then I will change it myself, I told you the situation in the service. There is no such thing, the oil is drained from the top, new oil is put on top, there is no adjustment, they said :) How are these guys going to drive me crazy? How do I order it from the sponsor section? / b> "
no money is paid to the master after every repair, once you say you have lifetime "Blink"
08.05.2020 16:12 # 20
metin
congratulations you did exactly as I described. I hope you have cleaned it thoroughly before siliconing, or it may not hold silicone, and when entering the vehicle puddle etc. until it dries well, be careful dry.
& nbsp;
if the sound comes from the shock absorber dust, which is usually the case, then the problem is solved.
Page : / 2
