Auto issue
08.05.2020 21:08 # 1
ucanturk
Greetings, I have the 2008 automatic 1.6 VTI vehicle. The transmission problem has increased. No problem at short distance. After 1 hour of use, he started to miss on the slopes. In recent days, even on flat road, he does not grasp first and then he gets up with a big shock. It is very annoying. If I act without waiting for a minute in the first runs, does it have a jerky friend (not related to the fuel system) or do I have a friend who knows the solution or knows a good master at Kocaeli? My vehicle is at 88 thousand km. Flying Turk 2019-02-03 21:44:51
08.05.2020 21:08 # 2
GokhaN
hi check the clutch lining and flywheel I think it's time to change
08.05.2020 21:08 # 3
As far as I know, Gokhan has improved al4 gearbox, which is called Porche Şazuman. possible solenoid valves are troubled. he needs to find a good gearbox and look at the pressure and fault codes with the computer.
