auto.geard fault
08.05.2020 15:21 # 1
ismail ozdemir
2002 model pejo 307 xt vehicle dun vehicle gave this error on the road. There is not much trouble in the food, but for example, when I stop in red, the vehicle does not start to go from d to empty when I pull my foot from the brake.
08.05.2020 15:21 # 2
monur
Your vehicle has a hydraulic pressure malfunction. It should have recovered when you start and restart it. Notice that it will not go to the last gear and the vehicle will put itself in protection mode in 3 th gear. If the engine speed decreases when you take your foot off the throttle while driving at a constant speed, the echo valves do not function. (sometimes it is very likely that this pseudo-fault will occur when the hydraulics gets too hot)
My advice to you, if the liar has failed, update the brain of the gearbox and install the latest version at a specialist garage.
08.05.2020 15:21 # 3
ismail ozdemir
What if I do not have a trip in the triptone, I take it there and it still looks what if I do not have a fault
08.05.2020 15:21 # 4
If the oil-solenoid valve is not the solution, the revision way appears.
08.05.2020 15:21 # 5
ozi033
I bought 2 electro valves. I have it right now. But since I couldn't find a master I can trust, I did not change it. Meanwhile, the transmission oil had changed 4 months ago. If I get this update, how will this update event? There is no machine in the masters outside .. I am waiting for your answers ..
08.05.2020 15:21 # 6
ismail ozdemir
could this be a malfunction and would it be a problem if i use it in this way?
08.05.2020 15:21 # 7
F-Eren
[QUOTE = ozi033] I bought 2 electro valves. I have it right now. But I couldn't find a master I can trust. Also, if I have these valves installed on someone outside, how will this update happen?
have these things done in the service so that you don't have a headache. You will cost 500 TL (oil + valves + labor + program)
08.05.2020 15:21 # 8
ismail ozdemir
my abs brain was malfunctioning, this automatic gear malfunction started to plug the brains out of place yesterday, the malfunctioning of the brain was re-inserted when it was re-inserted, no reversion to the revision is right now.
