Auto alarm
08.05.2020 17:18 # 1
206206
& Nbsp; & nbsp; Hello;
2006 model 206 ma & nbsp; I want to have an alarm. As far as I know, my car has its own remote control in car alarms. & Nbsp; Is the car 2 controlled? Can you give us information about this topic; What should I look for when receiving an alarm, friends ..
08.05.2020 17:18 # 2
herry
I had it installed, 206ma 2 years warranty 140 TL I gave the alarm system connects the control of the vehicle is working again, it is not canceled, but if you lock it with it, it is not active. If you lock it out of the remote control it gives you, you will activate it and you must regret it again. If you want, you can smash your key and combine it in a new container both as an alrm and key (do not recommend hiccc) or put an alarm control on the right of the orig key. Orginal electrical wiring cables of your vehicle are connected to the hole to get the news. When the alarm is active, the battery always makes current purchases and it is also inside the battery. Reviews
08.05.2020 17:18 # 3
Serkan
[Quote = 206206] & nbsp; & nbsp; Hello;
2006 model 206 ma & nbsp; I want to have an alarm. As far as I know, my car has its own remote control in car alarms. & Nbsp; Is the car 2 controlled? Can you give us information about this topic; What should I look for when I get an alarm?
08.05.2020 17:18 # 4
206206
last week & nbsp; the tape of my vehicle was stolen & nbsp;
I was thinking of getting an alarm and I got an alarm. but wouldn't it be healthy & nbsp; & nbsp; , Or & nbsp; I am afraid that it will ruin the electrical installation
in the case of a busted master
206206 2013-01-21 21:55:47 < / edited>
08.05.2020 17:18 # 5
herry
Wearing an alarm is not like having a music system started, you need to have a competent master do it, but if you are stealing, you can give an eye to the burglar but forget it.
08.05.2020 17:18 # 6
Bugra
There is an alarm in my car too, the owner before me had it built. but there are no separate alarms for the alarm, they are all on / off at the original key.
08.05.2020 17:18 # 7
werty
I would recommend cenmax, I have been using it for 2 years without any problems .. the car is working in accordance with its key .. there is no extra control problem. I had a price like 200 TL.
Get a good master connected. werty 2013-01-22 11:41:35
08.05.2020 17:18 # 8
Aziz
I had my old vehicle built. The event ends at the master, my friend, you will pay attention to the master, if you take it in my 30 lira,
I put it on my old vehicle, the first master has disturbed my vehicle, I lock the doors, open it, open it, lock it, my alarm was not active, I went the complaint & nbsp; the man was firing me almost from the shop, then I went to another master, corrected and made ten numbers, I could check both my own command and my car's control. I had 3 commanders.
08.05.2020 17:18 # 9
spearo
peugeot vehicle does not like the equipment installed on the original electronic equipment external installation, or have the original pug alarm installed, do not handle the tasting tool
08.05.2020 17:18 # 10
Alicilik
[QUOTE = spearo] peugeot vehicle does not like the equipment installed on the external electronic equipment, or the original pug alarms do not handle the tasting tool
Fixed with +1 experience
08.05.2020 17:18 # 11
Alicilik
In the meantime, I can give a good master recommendation "Ankara"
