authorized service cylinder head gasket replacement problem
08.05.2020 19:30 # 1
emresensoy307
friends 7-8 months ago until 307 1.4 I changed the gasket seal of my gasoline to the authorized service for 1-2 months, I have gone to the service again in the same place. As if it flowed right into the balls of the v-belt, I wonder if this gasket has lost its feature in such a short time and the authorized service guarantees this process for 1 year.
08.05.2020 19:30 # 2
ismailkaya
1.4 gasoline cars always make oil leak from the same point I have 307 1.4 gasoline in my car, I think I will understand the oil leakage for two years, so I have been careful about the oil, I think that it will be leaking from the rim of the pulley, but the service is escaping from the gasket, it is from the gasket, it is from the gasket, it is from the gasket, it is from the gasket, it is from the gasket, it is from the gasket, it is from the gasket, from the gasket, from the gasket, from the gasket, from the gasket, from the gasket, from the gasket. First, I will look at where the oil leaks are in a special place, and then they have received money until the world I will trade.
08.05.2020 19:30 # 3
emresensoy307
It is true, I bought the vehicle after 6 months, I think it would be better to have it done to the authorized service. I guess it would be a little bit later.
08.05.2020 19:30 # 4
emresensoy307
guncel
08.05.2020 19:30 # 5
First of all, I remember that the service gives mechanical materials to the mechanical materials that he has given a 1-year warranty and workmanship errors in 6 months. the gasket cannot be easily broken unless it is overheated. In one, when replacing the cylinder head gasket, it is sent to grinding in the upper block lathe so that we can not know what the service has done. As the brain says, the eccentric shaft may be damaged in the felt in the pulley. You have to remove and check the timing cover. If the oil gets on the v-belt, room trouble can even cause the strap to come out of its seat. I will have a check as soon as possible.
08.05.2020 19:30 # 6
serdaralisan
If the gasket did not burn, the cover would not be taken to grinding, there was no oil leak in the vehicles, the reason was that if I did not remember the sellock when the gasket was installed, it would be written, but they would say shellac, the masters would put it in a wire string, a cloth attached to it, and put the liquid inside the gasket. It is not very common, instead, there are liquid black gaskets, instead of installing the gasket, you can apply a thin layer with your hand to the places where the gasket will come from, and the gasket is installed on both sides, and if you want, I do not miss it. I glued it and bought a steel gasket on it. I applied it to the black mastic used by the glazers to attach the auto glass to the surface of each of them. there is heat, do not go to the authorized service if the warranty of your car is over, friends are placing them like arm, they make money for their job, sell parts, nothing else to the nation when we work in the service. cleaning the old room change valves, the smoke tires should be replaced while the belt is changed, the circulation is changed, the studs made elongation should be replaced, or the shirt pulls out, the oil filters are changed over time, the spark plugs escape in the spark plug cables, the price of labor increases, of course, you will understand that these are the efforts to make money. they will mourn
08.05.2020 19:30 # 7
serdaralisan
oil coming to the belt does not come out of the socket
08.05.2020 19:30 # 8
[QUOTE = if you are serdarra] Oil coming to the belt does not make it out of the socket [/ QUOTE] +
We learned something more. Thanks to Serdar.
08.05.2020 19:30 # 9
emresensoy307
In fact, I did not want to go to the authorized service and do it again if I did it because I wanted to get on my car for 1-2 years without any cost, so I got all the problems and got it back from the warranty.
08.05.2020 19:30 # 10
If you gave money to my teacher, the service will be made free of charge. I don't think it will happen, after all, there is an old felt and it needs to be changed.
08.05.2020 19:30 # 11
talip206
I have a little oil leak. This is a chronic problem. I didn't care much about the oil leak, but I was afraid that it would hurt because it was near the V-belt.
08.05.2020 19:30 # 12
emresensoy307
it was different 8-9 months or so soon this old gasket did not understand
