AUTAMATIC SHIFT PROBLEM
02.12.2020 23:09 # 1
refik
MY VEHICLE 2005 MODEL AUTOMATIC TRANSMISSION DISPLAY * S SIGN ON THE INDICATOR PANEL GIVES A BIP WARNING WHEN SPEED IS 30 KM FALAN. WILL BE DROPPED WHEN SWITCHING INTO THE GEAR. THE REVOLUTIONARY HOURS GOES 30, 40, THEN IT SHIFTS TO SECOND GEAR THANKS FRIENDS.
03.12.2020 10:30 # 2
fideliogs
I HAVE THE EXACTLY THE SAME TROUBLE, MY VEHICLE 2006 307 XT AUTOMATIC, CONTINUOUS KNOW THERE IS PROBLEM IN CONTINUOUS TRANSITIONS, AUTOMATIC GEAR SCREEN - - - SHOULD IT NOW I HAVE THE AUTOMATIC SHIFT SCREEN - - - IT IS NOW PULLING TO THE RIGHT, THE CONTACT OPEN, I HAVE A NEW STEAM, THE ANYWHERE IS STEADY ANY MASTER WHO CAN PROVIDE SOLUTIONS ON THE SUBJECT,
03.12.2020 11:01 # 3
muzzy35
The brothers had the same problem because of the same incident as yours, I do not know how I got rid of them. At once, he warned and took it to protect, again signs came out and it was at room oil temperature, brnimki they put on the lower guard and the sensor's worker at lower temperatures, I don't live in it right now. The oil change should not be more or less important, it should be placed in its exact setting. The room causes trouble.
10.12.2020 18:31 # 4
EmSul
revision, the last point, the revision should not work anymore, most of the malfunctions of the vehicle are solved without the need for revision, the important thing is to find a master who understands this gearbox. Ankara Yalova and Bursa have an automatic transmission, the solution is very good with al4 gearbox Kamil master talk to him first
13.06.2021 14:03 # 5
fideliogs
1 month ago, the solenoid valves were changed,
my master said, let's change the solenoid valves and try again before the revision, if the d disappears in motion and the s-kar mode comes out and the gear shifting stops, that is, if the malfunction continues, we will undergo revision;
exactly 1 month after the valves are changed. then the same situations arose again :(((
friends, is there no revision solution for this :((((
