Audio System Malfunction
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 308 (After 2014)
08.05.2020 21:23 # 1
askatn
I have a 2015 model 308 bluehdi vehicle. There is no sound from the radio or music system to the speakers. Sometimes it stops when the vehicle is stopped and restarts after a while. However, when it is stopped, it does not work again. I pray that every morning there will be sound. These days he never came. The problem is also unknown. the service says that the radio should be removed and sent for repair. The new radio price is around 6000TL. 1500-2000 TL repairs but not guaranteed.
08.05.2020 21:23 # 2
First of all, welcome to us. There were people who experienced similar situations, but I had seen in the forums of foreign sites, my teacher. If they only give this price to their repair, I think it seems much better to find a clean product at that price.
17.06.2021 12:35 # 3
metech459
My 2014 model Peugeot 308 Allure has a sound problem.
28.07.2021 09:49 # 4
Kamerakyel
I have the same problem, if you found a solution, please share it here.
06.10.2021 10:03 # 5
Safayu
I had the same problem with my 2015 -308 vehicle. While I was planning to go to a full service, my vehicle was lightly hit from behind. The sound system got better right after. No sound issues for 2 weeks. The problem I understand from this is a connector. I don't know exactly, but the socket to which the speakers are connected may be loose. It's not an electronic malfunction, I understand
09.10.2021 11:43 # 6
Yasarcan37
We bought a new 2016 model 308, the previous owner had a sound system, he said, the original sound system is now, he said, there is no sound from the speaker of the left driver's door, we did not notice if it was broken or they did not plug in the socket, I did not understand, moreover, the sound quality of the other speakers is very bad, I could not operate the rain sensor, the bitured parking sensor does not work either. I don't understand if it's broken or not, since I don't know the vehicle exactly, I will examine it in detail, let's see if the weather permits, it always rains.
16.10.2021 21:54 # 7
murtigo
08.04.2022 00:18 # 8
Erzincan24
Hello, I am new to this forum, could you please send the contact number of the master in Bursa?
23.04.2022 13:56 # 9
Joe_Dalton
Hello everyone,
It's been a pleasure to be a member of this forum, which I use from time to time.
I became a member just because I can help someone in solving this problem.
First of all, two problems with no sound coming from the speakers you are experiencing. I've had it once.
The first time, after long research, I played and played myself in the car for months without finding anything.
Until one day I took the back door trim off and checked the speaker. Unfortunately the speaker was completely rusted. When I remove the speaker and try, there is no sound because the system gives an open circuit failure and cuts the output. I replaced it with a new one and it was fixed instantly. Today there was no sound again and the first thing that came to my mind was the speaker I changed. We checked, it was immaculate. This time we looked at the other doors, let's see what happens. The speaker of the other back door was rusted. Of course, when it changed, it got better.
My advice to you is that you don't give credit to those who say that the sound system is faulty or the amplifier is burnt. First, check the rear door speakers. If there is corrosion, replace it because it is an open-circuit fault and the sound stops. Do not try without installing new speakers. I think getting water inside the rear doors is a chronic problem. Because I did not encounter any corrosion on the front. Also, don't be fooled by the audio pops because the same thing happened to me. Then it was completely cut off.
Big regards...
23.04.2022 23:05 # 10
talip206
ClapClapClap
11.06.2022 12:15 # 11
Enginn
Hello. Can you specify the communication and cost of the master in Bursa?
11.06.2022 12:42 # 12
Enginn
Hello. Can you share the master's contact information?
07.07.2022 11:15 # 13
impertore
Same problem happened to me. The radiator was punctured, they installed a new one and washed the engine. After that the sound was completely gone. There is no sound even from the parking sensors. The electrician connected the device and looked. The left rear speaker is broken and the system has locked itself. but I couldn't trust. because there was a problem after the engine was washed. I'll take a look at the rear speaker when it's available.
25.08.2022 01:37 # 14
Hayko
I have the same problem, whoever I go to finds a different problem. How can we reach this master
27.01.2023 17:12 # 15
Murat 18
Can you write the master's name and number ź
04.10.2023 11:01 # 16
zanderesas
Hello. How can we tell if there's an open circuit? Is it visible on the screen? Today, for the first time, I stopped hearing sound.
09.11.2023 10:00 # 17
Hkndlcy
Hello, I have the same sound problem in my 3008. Could you please share the contact information of the technician in question? Thank you.
24.04.2024 13:55 # 18
alex33
Hello, can you send me the information of the master in Bursa?
24.04.2024 13:56 # 19
alex33
Could you please send me the information of the repair shop in Bursa?
24.04.2024 13:59 # 20
alex33
