Audio assistance from 407 gear
08.05.2020 21:26 # 1
iso0625
Friends, when the vehicle exceeds 3000 rpm, there is a flickering sound starting from the bottom of the full gear lever. But when I removed the bellows, I came across a rubber protection. Does anyone know how to disassemble this? The sound comes from this.
08.05.2020 21:26 # 2
omerb
that yellowish thing is the jam nut. But I need to look at how to disassemble the bellows. I never disassemble. I can suggest this. If the bellows is soft at the bottom, there is a side that goes in that direction. Maybe it will be visible.
08.05.2020 21:26 # 3
iso0625
I tried pulling it up, but it didn't happen, hodja. If it is not removed from here, how to apply grease and soften the ridiculous gear.
08.05.2020 21:26 # 4
iso0625
[QUOTE = omerb] that yellowish thing, the jam nut. But I need to look at how to disassemble the bellows. I never disassemble. I can suggest this. If the bellows is soft at the bottom, there is a side that goes in that direction. Maybe it will be visible. [/ QUOTE]
I dismantled my teacher at last. There is a separate piece around that tire, like the tire, I pulled it up from the bottom after I removed it. I cut the tire from the bottom with a utility knife, but it came out like this. I hope I get lubricated.
