ATTENTION EMERGENCY EMERGENCY - EXPLOSION
08.05.2020 17:01 # 1
sukur
While my friends were coming from work, I got into my car after about 1 kM while I was driving, it wasn't 50 meters after my departure from the lights that a burst sound came under my car. With this explosion sound, I felt as if there was a gas or air outlet. for some reason. Because my vehicle was shaken. It was even so strong that a LINEAR man in front of me slowed down and looked at his own tires.
Since I was afraid I could not stop first, I switched the car to gas. So I went for a while, nothing visible in the tires or under the vehicle. I started my car again and continued on my way with LPG. I came about 30 km and never experienced the same thing. Believe me, I'm in a panic. I need your help. Such a strong explosion can result. What should I be afraid of? Let my car not go out in front of my eyes ...
Please everyone who has an idea write
08.05.2020 17:01 # 2
sukur
the subject is up to date ....
08.05.2020 17:01 # 3
sukur
NO PREDICTION
08.05.2020 17:01 # 4
mev347
it may be due to gas compression. I suggest you do not neglect.
08.05.2020 17:01 # 5
brutal
I think you need to go to the nearest LPG expert because the vehicle does not burn the LPG. and the gas that bursts burst. Just like the tofascists who make noise from the exhaust, they fire the vehicle gas and then ignite it.
08.05.2020 17:01 # 6
muro_60
This type of explosions usually makes the ignition system and gas adjustment. If the gas is not set up, the spark plug range will be corrected by 0.70, the performance will increase. Regards.
08.05.2020 17:01 # 7
Haksen016
08.05.2020 17:01 # 8
Haksen016
urgently gas connections etc. have it checked.
08.05.2020 17:01 # 9
badcombatant
Check lpg and ignition system, make gas measurements of bidet vehicle. Do not neglect this lpg
08.05.2020 17:01 # 10
AydinBeyol
Get well soon. I say take it to an LPG master immediately ..
08.05.2020 17:01 # 11
goktug
Get well soon..
08.05.2020 17:01 # 12
sukur
Thank you guys for your interest. You are all very good. God bless you. I'm going to mon check. The car doesn't eat gas when I first start it in the morning for the last week. I think it's something about that again. Thank goodness my car did not flash in front of my eyes. I will take it on gasoline and go on Mon day and have it checked. As a result, I would like to inform you for those who live after me. Greetings to everyone.
08.05.2020 17:01 # 13
sukur
Guys, I went for control. But there is no solution. There was no problem with the tests. Nobody could say anything because he didn't always do it. I left the industry yesterday, I was still driving 40-50 km on the slightly down sloping road & nbsp; GUM left anyway from what he threw. What am I going to do?
08.05.2020 17:01 # 14
muro_60
If my friend gas setting is normal, he will ignite the spark plugs. I said 0.70. uneven ignition, which means that I washed the engine in the last night, but the water blew spark plugs made the same explosion at that time, cleared up & nbsp;
08.05.2020 17:01 # 15
sukur
[QUOTE = muro_60] my friend makes the gas setting normal without ignition if the gas setting is normal. uneven ignition, which means that I washed the engine in the past night, and the water blew spark plugs made the same explosion at that time, cleaned up & nbsp; [/ QUOTE]
Spark plugs 0.70 said the man. He put it on the computer and nothing came out. What should I do, Muro? Should I go to the master and say clean anyway?
08.05.2020 17:01 # 16
erden1978
It is important for the gas you take.
Buy gas from a different station when the tank is empty.
08.05.2020 17:01 # 17
mustigiz
did the problem go away? I wonder why?
08.05.2020 17:01 # 18
35_gti_35
lgp does not neglect my teacher, watch out, show it to bio
08.05.2020 17:01 # 19
muro_60
May Allah not do it, is your vehicle 206 8 valves?
08.05.2020 17:01 # 20
muro_60
and the explosion is making me pressurized gas. Is there a tremor at the meeting
Page : / 2
