Atiker LPG Conversion
08.05.2020 19:21 # 1
tolgaakk
Hello, my car was 1,4 206 in the previous location and I was very pleased with the consumption values of the Atiker kit about 2 months ago. I wanted to share the values with you. Since my tank is 32 lt 80 percent filling, I get a maximum of 25 liters. When I bought 2.16 tly 25 lt from Shelld, I made 290 km in Ankara, which corresponds to 18 kr per km. I recommend it to everyone who was incredibly relieved after having a tube.
08.05.2020 19:21 # 2
rebel_43
18 krs urban use is very afternoon 😊 janjanlı € 522; Have you ever been out of my banner 30 - 35 krş.sen
08.05.2020 19:21 # 3
tolgaakk
I hope he will go out on his feast, then I will share my consumption here again
08.05.2020 19:21 # 4
Where was the total cost of Tolga in Ankara?
08.05.2020 19:21 # 5
tolgaakk
I had a safefast obd2 kit in the new Baskent industry onder autogas, but I definitely do not recommend it. My car did not work on the day when it was first installed, the idle was still fluctuating, while using LPG, it was singing in the bottom gas.
08.05.2020 19:21 # 6
I am glad that the problem to go to superior autogas should be resolved :) What is the total cost for you to operate the license right now .. sonerkyl 2015-07-07 11:56:15
08.05.2020 19:21 # 7
tolgaakk
Thank you :) The top autogas on the abbas master alineri boulevard. If I remember incorrectly, I went to the licensing process of around 400 TL, but I had a lpg conversion to 1600-1700 TL in total in the license, which had been filled in two sheets, so two leaves had changed.
08.05.2020 19:21 # 8
I have my vehicle fitted with superior autogas to atiker obd 2 1150 tl, which will be lpg from today.
08.05.2020 19:21 # 9
KILIC
[QUOTE = sonerkyl] My car is going to be fitted with LPG, which will be lpg from today, at 1150 TL in superior autogas. [/ QUOTE]
Good luck soner goodbye bin lpg cander at these gasoline prices :)
08.05.2020 19:21 # 10
Exactly, I have planted a tree of fig, I already have 2000 km per month.
08.05.2020 19:21 # 11
tolgaakk
Soner teacher good luck lpg lpg has relieved me very much.
08.05.2020 19:21 # 12
thank you. I left it in the morning, now I received the vehicle tolga superior lpg assembly. I have come to work, there is no difference in gasoline, there is no idling fluctuation at the moment, they made assembly work nice and clean. Let's hope it won't cause any problems in the future. Now the vehicle has only airbag wrap left, I will have it built and go to the inspection.
08.05.2020 19:21 # 13
I will ask you something tolga. Does your car exceed 90 degrees in heavy traffic. otherwise my vehicle has a problem.
