assistance with engine oil .....
08.05.2020 20:02 # 1
abokam
I bought Mobil 1 ESP Formula 5W-30 4LT DPF Vehicle Gasoline Diesel Engine Oil.
08.05.2020 20:02 # 2
oguzhan53
Fine income, my advice 5w40 will be more suitable
08.05.2020 20:02 # 3
abokam
DPF DO YOU TROUBLE OUR VEHICLE IS TRYING FOR THE ENGINES WITH DBF FOR THIS OIL
08.05.2020 20:02 # 4
ichetin
Guys put my car 2004 pejo 307 gasoline gas 10 40 shell put it harm
08.05.2020 20:02 # 5
ardinal
In the last maintenance for 1.4 HDI, I put it from the same oil. I have not seen a problem until now. Being suitable for vehicles with DPF does not mean that it is incompatible for vehicles without DPF system. I had researched. I did not sense a fault condition of 7 thousand km. I think use it if you bought it. But I will also use the Mobile Super ™ 3000 X1 5W-40. Fully synthetic and fully recommended for the vehicle.
Extra: DPF compatible oil is very important for the vehicle with DPF system. But it does not matter if it is not DPF compatible in vehicles without DPF system.
3.8 lt oil amount for my vehicle but they dumped 4lt. In other words, 200ml does not cause any problems but I am in a situation of adjustment. But when I looked at the booklet of the vehicle later, I saw that it wrote 3.8 with the filter change. Put 3.5 liters of oil into the vehicle. Throw the leftover in the trunk. Occasionally check your oil. If it makes a reduction, you add it if it falls below the vehicle and its minimum level. I'll do it for you :): D
Buddha picture, get a nap, it works for you :)
Ardinal 2016-11-18 13:53:22
08.05.2020 20:02 # 6
Vefa
My 206 hdi 1 month ago, I had the maintenance, the masters used 5.30 castrol edge. The car's voice decreased compared to the previous one.
08.05.2020 20:02 # 7
ardinal
If your engine is in good condition, there will be no problem. It would be even more beautiful. As the part of 5w30 syntax that says 5 drops, the oil's high fluidity is high. While it cannot start the 10w40 engine in very cold weather or prolong the time it takes for the engine to run, it can start the 0w40 engine and quickly reach its consistency and reduce the wear. The higher the part that says 30, the higher the thickness when the engine is hot. While the engine is very hot, the oil may decrease, since the oil of 5w30 viscosity will remain thinner than the oil of 5w40 viscosity. In the right oil selection, the condition of the engine of the vehicle is as important as the climatic conditions are taken into consideration. If it makes you very hairy, check your oil from time to time, if it makes excessive reduction, you can try 5w40 10w40 gradually :) If you are satisfied, you can use it if it is not satisfied in the vehicle :)
synthetic oil / mineral oil difference
http://www.mobiloil.com.tr/turkey-turkish-lcw/heavydutyoils_why_synthetics.aspx
viscosity
http://www.shell.com.tr/products-services/on-the-road/consumer-lubricants-tpkg/right-oil.html
5w30 can be used for 206. For your peace of mind :)
http://www.peugeotmarket.com/filtre-ve-bakim-urunleri,la_774-2.html#labels=774-2
Ardinal 2016-11-18 14:48:35
08.05.2020 20:02 # 8
Vefa
The condition of the engine is good and it sounds better than before. Thank you for your information.
08.05.2020 20:02 # 9
esstel
I use mobile 5 w 30 for my 1.4 hdi vehicle .. no problem ..
08.05.2020 20:02 # 10
abokam
tskler friends information was useful ...
08.05.2020 20:02 # 11
dejawu1978
When the subject first opened, I added oil change for short care, but my repairman said 10x40 for oil ..? this is not fat
I guess to our vehicles
08.05.2020 20:02 # 12
ekinoks44
I think they put 10x40 oil in my master, they think this is appropriate for oil reduction, etc.
08.05.2020 20:02 # 13
dejawu1978
I found a site here which shows which oils of the vehicle can be used ......
Click on the icons such as car / van from the above icons and type the information confirm
this is the oil my car can use
