Assistance to light gas space sharing |
| 08.05.2020 18:46 | # 1 |
| 08.05.2020 18:46 | # 2 |
muro_60 |
Since the pedal is electronic, there is a gap. |
| 08.05.2020 18:46 | # 3 |
so how is the solution
| 08.05.2020 18:46 | # 4 |
muro_60 |
http://www.btgmaslak.com/urunlerimiz/sprintbooster you will get it
| 08.05.2020 18:46 | # 5 |
muro_60 |
http://www.hepsiburada.com/liste/sprint-booster-gaz-tepki-arttirici-peugeot-307-2006-2008/productDetails.aspx?productId=otbtg001pe3070608&categoryId=60002903 good money :))
| 08.05.2020 18:46 | # 6 |
I do not think it is related to the products you call, the original you know is breaking down the car
| 08.05.2020 18:46 | # 7 |
muro_60 |
[QUOTE = pekmez006] I do not think that it is related to the products you call, the original you know is broken, the car [/ QUOTE] does not understand how you want it, the socket is not broken by the orig, and their gases will always be like this.
| 08.05.2020 18:46 | # 8 |
My friend, all different branded vehicles with electronic accelerator pedal transmit the accelerator pedal response in delay of 0.8 - 1 second. If you write "gas reaction" on the web and search, you can get more detailed information about the subject. I am suffering from the same problem, In my 1.6 gasoline vehicle I just bought, the Pedal is receiving a delayed control, and the clutch pedal could not be adjusted to grip lower. What shall we do, we will get used to this situation. I do not plan to pay as much as pedal booster eo. |
| 08.05.2020 18:46 | # 9 |
[QUOTE = palette] My friend, all different branded vehicles with electronic accelerator pedal transmit the accelerator pedal response in delay of 0.8 - 1 second. If you write "gas reaction" on the web and search, you can get more detailed information about the subject. I am suffering from the same problem, In my 1.6 gasoline vehicle I just bought, the Pedal is receiving a delayed control, and the clutch pedal could not be adjusted to grip lower. What shall we do, we will get used to this situation. I don't plan to give as much money as the pedal booster eo. [/ QUOTE] we'll get used to it, then the world will be more than giving money :)
