ask the electric master
08.05.2020 15:22 # 1
ince oto elektrik
arkadşlar electrical & mechanical problems & nbsp; and msg in your questions is enough or I try to answer your questions on this subject ....
my goal is just to help and & nbsp; problem nobody misunderstand ...
08.05.2020 15:22 # 2
mustafa486
my intermittent wipers do not work. In mild rain, I manually wipe it by hand. No problem with the rear wiper. Is it my relay failure or my fuse? where the relay did not find the fuse panel. Thanks
08.05.2020 15:22 # 3
tigerland
or manager, when I open the fog, there is a sizzle in the sound system. I pressed the gas until the end of the gas, I cut it, I do not understand why I have a short circuit, there is a short circuit, I changed the left fog bulb.
08.05.2020 15:22 # 4
oguzhan29
There is no broken lamp in my car, when I lock the car when the four are on, my left parking lamp lights up with them when I give a signal to the left, no problem when I press the brake, the left signal lamp is speeding up and clicks.
08.05.2020 15:22 # 5
GiTaRRa
my teacher, because you provided such an option. If he has insurance or something, let me take him to the service when he passes the examination ...
08.05.2020 15:22 # 6
ince oto elektrik
[QUOTE = mustafa486] intermittent wipers do not work. In mild rain, I manually wipe it by hand. No problem with the rear wiper. Is it my relay failure or my fuse? where the relay did not find the fuse panel. Thank you [/ QUOTE]
& nbsp;
I don't know how many models of the vehicle, but I guess there is definitely a malfunction in the 2001 bsi brain or the eraser motor or even one of the eraser arms or 3 of them ...
08.05.2020 15:22 # 7
Muhammet CAKIR
thank you brother boyle b for help :)
08.05.2020 15:22 # 8
ince oto elektrik
[QUOTE = tigerland] manager when I open the fog, there is a sizzle in the sound system. I am pressing it until the end of the gas, I do not know why it is cut off, there is a short circuit, I have changed the left fog bulb in some place or if it is the gas because it is GT, it is recovering from fear: D [/ QUOTE]
if you attach tape to the vehicle, these kinds of complaints can come. If you are using tape, you can do it from the antenna, on the radio.
08.05.2020 15:22 # 9
ince oto elektrik
[QUOTE = oguzhan29] There is no broken lamp in my car when I locked the car when the car is on, my left parking lamp lights up with them when I lock the car. No problem when I press the brake. could be from the brain or something [/ QUOTE]
back left & nbsp; stop is not getting a chassis so you are faced with something like this, an electrician can handle it, not from the brain.
08.05.2020 15:22 # 10
ince oto elektrik
[QUOTE = GiTaRRa] teacher, because you provided such an option. I will go to the examination, but the airbag lamp stops blinking, I couldn't find it connected to the machine. If he has any insurance, let me take him to the service after the examination, diorum ... I don't need it or because it doesn't read the heavy bag brain, it doesn't seem to be a malfunction or the heavy bag brain is not recognized by the device. Insurance is not something that can be removed and taken care of.
08.05.2020 15:22 # 11
ince oto elektrik
friends also asking for malfunctions brand and model of your vehicles I would provide more healthy information
08.05.2020 15:22 # 12
GiTaRRa
106 2000 model 1.4 I hope it passes the examination ..
08.05.2020 15:22 # 13
Hello. My vehicle is 2004 model 206 Quiksilver. 1.6 110HP at 103k km.
I have idling fluctuation and slight misfire problem. While the vehicle is idling, the tachometer plays very minimally. It's not a problem, but it occasionally nods while the vehicle is still idling. I cleaned the throttle, it was not resolved. I used an injector cleaner and it cannot be said to have benefited much. Why could it be caused?
08.05.2020 15:22 # 14
As you said mechanical and electrical, I'm sorry.
08.05.2020 15:22 # 15
ince oto elektrik
[QUOTE = Cindy] Hello. My vehicle is 2004 model 206 Quiksilver. 1.6 110HP at 103k km.
I have idling fluctuation and slight misfire problem. While the vehicle is idling, the tachometer plays very minimally. It's not a problem, but it occasionally nods while the vehicle is still idling. I cleaned the throttle, it was not resolved. I used an injector cleaner and it cannot be said to have benefited much. Why it may be caused?
08.05.2020 15:22 # 16
SAVAS
I have my master 2004 model 206 hdi. How do I connect navigation to a facility that can be activated by contact, not to the cigarette lighter?
08.05.2020 15:22 # 17
Topic exploded gone & nbsp; "Laugh"
08.05.2020 15:22 # 18
HRMNKY
Thank you very much for opening such a title. Thanks to you, our friends will be able to find answers to all kinds of problems.
08.05.2020 15:22 # 19
insomnia
Master 2000 model I have a 306 XR vehicle, the more I go to the bottom trigger mode, the more it progresses, it does not automatically do not automatically. > rear wiper without problems insomnia 2011-05-03 09:11:10
08.05.2020 15:22 # 20
cash1912
I have problems with our user named berkay. throttle contact gasoline filter spark plugs I did replace the battery, but still fluctuation continues and the car does not start the first start. The reason for these problems is thanks to the ignition coil.
Page : / 3
