Ashtray lamp :)
Homepage » PEUGEOT MODIFIED PLATFORM » How To
08.05.2020 16:02 # 1
heffera
the cigarette ashtray lamp is not lit, but I do not know if it is too ... there is something red on the side but it is not lit. it is useful if those who know ...
08.05.2020 16:02 # 2
MemoTech
That lamp lights up with the parks. If it does not burn, the ashtray is removed, the lamp and socket are visible on the left side, it is flexibly displaced and the bottom indicator bulb is called, the name is T5 1.2w, the bulb is replaced with a new one. Burning is observed :))
08.05.2020 16:02 # 3
MemoTech
I wrote the one for 206, I can't see your car, it's probably the same now, and this is the system in others. The bulb I remember correctly will be this bulb. The price is very cheap, 50 cents or something. Many bulbs are used in interior and indicator lighting.
MEMOTECH 2011-08-25 04:28:24
08.05.2020 16:02 # 4
werty
Yes, I changed this lamp in me. When I got out of the club, the lamp inside a brown piece on the left side comes out.
08.05.2020 16:02 # 5
heffera
tşk
08.05.2020 16:02 # 6
I removed the lamp the other day, where can I find it?
08.05.2020 16:02 # 7
deamod
Friends in my car there is a lamp in this ashtray, but when I remove the ashtray, there is no lamp, nor does the lamp socket have a female socket when I disassemble a vides blister. I don't think that it is for the lamp. if so, where is the socket
08.05.2020 16:02 # 8
[QUOTE = deamod] Guys, I have a lamp in this ashtray in my car, but when I disassemble the ashtray, there is no lamp, nor the lamp socket has a female socket when I disassemble a vide blind. if so, where is the socket
Something like that might look at you:
There are two different versions according to the production date.
Lamp and socket number 73-74 in both of them.
Koliva 2011-08-30 12:01:10
08.05.2020 16:02 # 9
deamod
Koliva, thank you. Do I have to disassemble this 73 to 74 electrically to find out I don't know where or there is?
08.05.2020 16:02 # 10
CHK35
I have it too but it exploded. I hope we can find a very interesting bulb.
08.05.2020 16:02 # 11
Ozel6521
I recently built my car 307. You need 3 identical bulbs anyway. only the coating will be removed. After the gear bellows, it seems that the coating to which it is attached is removed. But don't expect much from that light, so I made it eagerly Smile
08.05.2020 16:02 # 12
suppor
I was able to fix the bulbs of the place where the date time is, I was able to fix the same bullet of the console or all of the same thing. supper 2015-02-08 01:37:49
