As the temperature rises, traction falls
08.05.2020 18:42 # 1
elbo48
I need help urgently my car 307 1.4 hdi problem when the car first starts trembling in the car, the speed indicator plays the accelerator pedal, the pedal does not function when it waits for 30 seconds. 2. my problem is the temperature in the car 90 passed, the car is falling on the slopes officially dying I can not even go with 30. I have to pull the car to the right and cool it. ConfusedConfusedCryCry
08.05.2020 18:42 # 2
emrepunar
If you want a check of the coolant of the vehicle may have burned the gasket.
08.05.2020 18:42 # 3
elbo48
cooling water does not decrease, the level is the same only when the temperature is high in hot weather, the performance is over.
08.05.2020 18:42 # 4
ahmed206
I wonder if the temperature seems 90 to you, is it actually 120-130 degrees?
08.05.2020 18:42 # 5
elbo48
If the gasket is burned, it is necessary to reduce the water, if it is clogged or not, it is always clogged or not, but I do not understand the difference.
08.05.2020 18:42 # 6
emrepunar
evt diminishes but you can still control a water booth for the sister.
08.05.2020 18:42 # 7
Foxfire
If my friend is a one with a normal dial, check the device and connect it to the device, and the temperature on the computer in my computer hit the bottom in 206. I thought it was doing the temperature.
08.05.2020 18:42 # 8
elbo48
The first time I start the car, the circuit is falling down, the gas pad does not work, it does not react, it changes after a while, sometimes it does not work, the mars does not work, the fault lamp does not light up. I connected it to the computer. biliyormusunz
08.05.2020 18:42 # 9
lead38
Change overhearted condition will definitely correct. This malfunction does not appear on the computer. The same thing happened to me.
08.05.2020 18:42 # 10
Gokhan Cetin
I had the same problem in the first time, when I did it, I fell from 5th gear to 2, then I realized that the temperature of the protector around the turbo was going to smoke.
08.05.2020 18:42 # 11
elbo48
what the temperature sensor will look at. What is the breakdown that I call the accelerator pedal cause?
08.05.2020 18:42 # 12
Foxfire
[QUOTE = elbo48] the car starts to cycle, the gas pad is not working, it doesn't react at all, it is fixed after a while, sometimes it does not work. Do you know a master who understands well in places
If you fall in Izmir, we can show it to my master
15.02.2021 17:23 # 13
TRK
[QUOTE = Foxfire] [QUOTE = elbo48] The first time I run the tool, the cycle drops off, the gas pad does not work at all, it does not react at all. I will be crazy, do you know a master who understands well in places like mugla and intellectuals
If you come to Izmir, we can show it to my master
Which master in Izmir?
