as if the stove is burning in the vehicle ...
08.05.2020 18:35 # 1
Haydut06
Hello friends..
My vehicle 2001 206 XT
I have noticed for 3-4 days (did I know it was before, I just noticed, I do not know if it is normal or not) Think of it as the bottom right part of the steering wheel, the continuation and back of the tape and heater body .. there is a part that connects the plastic and the motor. Even on a 7-8 km road, it gets very hot, almost untouched. When I was driving, I can say that my feet burned. Where did this temperature come from? As I said before, it was so hot before I do not know I did not pay attention ..
(The temperature rises up to 100s in normal heavy traffic, decreases to 90s when it turns into a cruise. It rarely rises between 105-110 when traffic is difficult)
Is there a temperature situation that bothers you in your vehicle? Note; The clutch change time of the vehicle will be handled as if it is approaching, but it will be good if it changes .. does it have anything to do ..
08.05.2020 18:35 # 2
pusutr
It is not normal to say that there is no such problem with me. I say, look at a master.
08.05.2020 18:35 # 3
newlook45
I do not have a warming problem, but if you find a solution to the same temperature, I would be glad if you share it.
08.05.2020 18:35 # 4
KILIC
Is there any water shortage, can you check the radiator water in the vehicle.
08.05.2020 18:35 # 5
enderdmed
I had written on another subject about this before, my friends, I had a similar problem.
08.05.2020 18:35 # 6
Haydut06
If there is no warming problem, it means there is a problem, but what is understood. When it comes to temperature, the temperature indicator has been around since the first day I received, so the average is 90, according to the traffic situation, the maximum is 110, but when it turns into a cruise, it drops to 90 again.
What a problem car, friend, we could not solve a problem 3 years ago, but I do not know the account of the money I spend.
the result is that this tool will cost me again :)
08.05.2020 18:35 # 7
Haydut06
I went down and looked at the radiator water, but I was not looking for a normal month, I added half a glass. I'll take it on Monday.
08.05.2020 18:35 # 8
ahmed206
The overheat normally does not exceed 100 in mine. The only way to pass 100 is to stat it when the car is very hot and start it again after 5 minutes. That is when he works at 110 and immediately goes back.
08.05.2020 18:35 # 9
KILIC
I had the same problem in my 307. My right leg burned in front and it would be so hot. I changed the oil or something, put antifreeze on the radiator of the car and then there was no heating.
As for the temperature, my normal teacher is 90-100 normal, especially if the vehicle has LPG, then it is very very normal.
