As if someone is holding the car, an interesting problem |
| 08.05.2020 20:53 | # 1 |
My vehicle is 2006 1.4 hdi, do you have any idea about it, thanks in advance.
| 08.05.2020 20:53 | # 2 |
Adem Kurtuldu |
The turbo could be something like that, the turbocharged turbocharged cycles could be something like hoses, but if it is constantly driving, if the vehicle is uncomfortable, it might be problematic or full of catalyst.
| 08.05.2020 20:53 | # 3 |
Again, the cost is patterned
| 08.05.2020 20:53 | # 4 |
Is this exact catalyst thing? I will change the supplier industry for a few days, but I hope it is nothing more. egr if i had a cancellation i didn't know
| 08.05.2020 20:53 | # 5 |
It becomes a partner to my salary every month, this 206th km more 146 thousand. before that I had a megane 2 hb 1.5 dci vehicle. I bought it in 160 thousand and sold it in 220 thousand. For so long time, only the glass opening module had been broken.
| 08.05.2020 20:53 | # 6 |
[QUOTE = sabuda34] [QUOTE = breakbeat] Is this exact catalyst thing? I will change the supplier industry for a few days, but I hope it is nothing more. egr if i had a cancellation i didn't know [/ QUOTE Have you read similar complaints from different brands of google summer? The common complaint is that when you hit the gas, they say someone is hanging from the back of the vehicle. catalyst failure occurs in all of them. started to clog, it will be completely clogged soon. increases in gas consumption. this is the cylinder in the catalyst manifold boiler. A filter like brick, woven in a similar way to bee honey. The vehicle is due to low speed and cheap fuel usage. no matter where you look at the original catalyst, around 1500-2000 TL supplier industry and dating will not make you smile. short-lived no need to gamble. The fate of diesel vehicles is the catalyst. a dirty fuel compared to diesel fuel I researched what happened, I will not cancel, but unfortunately I can not afford to pay that much money in the original. If I find a place that actually does a solid cleaning, I try a clean first. There are videos on YouTube, they disassemble and pour medicine and boil a lot of dirt. Even if it is not 100% cleaned, I think at least it will still be useful. Or I will buy a quality sub-industry product. Let me investigate a bit first. I bought this vehicle since I bought it because its price is affordable and the case is up to date, but since I bought it, I spent a lot of money but mine was a bit of arbitrary expenses, 4 tires, timing, circulation, v-belt, etc. exchanges. I also replaced the alternator bearing and starter automatic. Anyway, I will handle it in a way. Thank you for your help. Thank you for your support.
| 08.05.2020 20:53 | # 7 |
I also had a traction problem with 307 1.4 hdi. I used the liqui moly brand catalytic cleaner. but my current vehicle is also no catalytic zero zero is better than emptying with 275 TL metal element makes a lot of noise when you empty it
| 08.05.2020 20:53 | # 8 |
[QUOTE = emrahyilmaz84] I had 307 1.4 hdi traction problem, I also used the liqui moly brand catalytic cleaner. but my current vehicle is also no catalytic zero, but it is better than emptying 275 TL with a metal element makes a lot of noise when you empty it [/ QUOTE] I guess that? |
| 08.05.2020 20:53 | # 9 |
[QUOTE = breakbeat] Hello guys, I noticed something in the car 2-3 days ago. There is nothing wrong with departures. Something like holding the car between 2000-2200 rpm. There was no such thing before. When the 2200 cycle has passed, there is no problem, but when going between the cycles I said, the vehicle is constantly as if going back and forth. By the way, the vehicle doesn't malfunction. 1 month ago I changed the triger, circulation, v-belt and its bearings. My vehicle is 2006 1.4 hdi, do you have any idea about it, thanks in advance. [/ QUOTE] km sender may be km sender is like a car, if the internal mechanism makes it malfunction, the vehicle hurts, it does not go even if it gives gas, even occasionally (it is noticeable on the long road), if it occurs with it, then you tear the vehicle with 50 liras.
| 08.05.2020 20:53 | # 10 |
vehicle kiosk kiosk kiosk kiosk demi km sensor. The customer is not bad at all, 50 pounds |
| 08.05.2020 20:53 | # 11 |
It does this very regularly and systematically. Leave it. Leave it. Leave it. if I increase the speed a little, it returns to normal. I called as km sender. The km sensor came out, those who had problems in the speedometer used the km sensor. Do you have a link to the piece you call |
| 08.05.2020 20:53 | # 12 |
okay it's likely to be from him
| 08.05.2020 20:53 | # 13 |
I solved the problem. Sensor entering turbo hose burst
| 08.05.2020 20:53 | # 14 |
I just taped the hose for now. I placed an order to manage it until it came
| 08.05.2020 20:53 | # 15 |
[QUOTE = sabuda34] [QUOTE = breakbeat] It becomes a partner to my salary every month, this 206th km is 146 thousand more. before that I had a megane 2 hb 1.5 dci vehicle. I bought it in 160 thousand and sold it in 220 thousand. For so long time, only the glass opening module had been broken. [/ QUOTE] my 3rd pejo. 206-207-308. a troubled car pejo. Lying saying "I have no problems." It's been 2 months since I bought my own car. It opened a total cost of 2500 TL. Even though years passed, I prefer the pejo because it is a permanent vehicle and equipped vehicle for other brands according to money. I bought the vehicle to 38. At 65 thousand km When I bought it, they wanted 40 thousand in 2000 model golf in 80 thousand km. there is a 9 age difference. what do you prefer [/ QUOTE] Everybody is a liar, you are right. If it's that bad, don't take it. if you are piled up, guilty people?
