Are you happy?
08.05.2020 16:15 # 1
Tomorrow I will get 6 installments in the morning, if it is still the battery. 75 amps happy 160tl
74 amps varta 180tl (the battery suggested this)
60 amps happy 125
60 amps varta 145
< br>
all prices have fallen 26tl, there is no installation etc in the car but my choice is 75 amps because it may be in the future. It is difficult to say, is it true?
I have had a lot of questions, but I have one more question. Do these batteries have a production date or something, as we were buying tires?
08.05.2020 16:15 # 2
I also think that the battery installed after the vehicle's battery coming from the factory will not last for 5 years and I have seen it in a short way.
& nbsp;
If I were I would prefer to buy Varta
08.05.2020 16:15 # 3
Muhammet CAKIR
VARTA & nbsp; It is a very solid brand, so it is happy, but there is 20 TL difference between the varta and there is 20 TL difference.
08.05.2020 16:15 # 4
I do not think it will be so big between vatra and happy. You can get both. & nbsp;
08.05.2020 16:15 # 5
We have never used Varta. My grandfather is a tradition since his time. Once fabricated, we encountered an error and changed it under warranty. It was between 4 and 10 years in life depending on vehicle and installation.
08.05.2020 16:15 # 6
sedataksu
Happy is really quality.
08.05.2020 16:15 # 7
The original of the car is 60 amps. But I heard from many people that it would be better to install 75 in the 1.4 diesel car since the engine is small.
08.05.2020 16:15 # 8
[QUOTE = CeCoLi] I am of the opinion that the battery installed after the vehicle's battery is not going to last for 5 years and I have seen it in short.
& nbsp;
I would have preferred to buy Varta
My father said the same thing now. He said high, the battery is what it is not the standard, the starter motor will draw the current
08.05.2020 16:15 # 9
sedataksu
I don't know the variant, but if the happy siver series (better) the price is normal.
08.05.2020 16:15 # 10
If the power of Mars is left to me, it can be an expression in the language of the people. It is also related to the quality of the battery. Let's consider two 60A batteries. Considering that we are doing long-term mars with both of them, we normally expect that it will make mars with the same strength for 2 years. However, when the vertebrae and quality reach the heat, there may be differences between them.
08.05.2020 16:15 # 11
Well, Cem brother, I have something else on my mind.
08.05.2020 16:15 # 12
[QUOTE = HuseyinTurk] Well, there is something else I have in mind. DIV> & nbsp;
It is not a difference that will be of great importance. & Nbsp; It just takes a little longer to charge ... I guess so much ...
08.05.2020 16:15 # 13
sedataksu
The starting value of the starter is the current value it will draw when giving the first movement. If you install 60 amps to a 72 amp vehicle, the vehicle will not start. Similarly, if you add 100 amps to a 60 amp vehicle, the starter motor may burn. Its value is 80 amp. while & nbsp; 100 amp. battery is not used.I might be wrong, my general knowledge is about electric motors.
08.05.2020 16:15 # 14
"Thumbs & nbsp; okay, let's get 75%, I will buy it once and finally I will decide my happiness there & nbsp ;
08.05.2020 16:15 # 15
Didn't you listen to my colonel? The man shouted head-to-head 72 Amp Happy Battery & nbsp; "Grin"
08.05.2020 16:15 # 16
[QUOTE = sedataksu] The current value of the starter motor when starting the first motion is the current value it will draw. If you install 100 amps in a 72 amp vehicle, the starter motor may burn. Max current value is 80 amp. while & nbsp; 100 amp. battery is not used. I may be wrong. My general knowledge is about electric motors. .The amount of water flowing from the tap is limited, i'm discharging 10 liters per hour. This is the value of 12 volts in the battery. The ampere is the capacity of the pool. I can be wrong too, if it corrects, I would be glad if those who know are wrong.
08.05.2020 16:15 # 17
[QUOTE = csalli] Didn't you listen to my colonel, hee !!! The man shouted head-to-head 72 Amp Happy Battery & nbsp; "Grin" [/ QUOTE]
let me get a message 83 times a day, albaya is already 72 amps, even just to get better than it, i will get it more expensive it :)
