Are these 2 brains compatible with each other?
08.05.2020 21:07 # 1
f4t1hltn
Hello everyone. Are the 2 brains I uploaded photos compatible with each other? And how much does it cost to transfer between two brains and software? Vehicle 2004 model Peugeot 206 1.4 petrol LPG li
f4t1hltn 2019-01-10 12:46:12
08.05.2020 21:07 # 2
GokhaN
Does not hold any numbers 99% does not fit
08.05.2020 21:07 # 3
f4t1hltn
Gee. He said it was impossible not to match the place I bought, the master is not compatible but we will try to code it, he said. What should I do? I'm confused now
08.05.2020 21:07 # 4
GokhaN
[QUOTE = f4t1hltn] Allah Allah. He said it was impossible not to match the place I bought, the master is not compatible but we will try to code it, he said. What should I do? I'm confused now [/ QUOTE]
When you make up a master, just check everything that the vehicle is running, control everything about air conditioning, glass, lock, headlight, stop etc.
08.05.2020 21:07 # 5
f4t1hltn
Thank you very much for the information :) Other than praying for adaptation, the remedy is not visible for now. Thumbs Up
08.05.2020 21:07 # 6
GokhaN
[QUOTE = f4t1hltn] Thank you very much for the information :) There is no remedy other than praying for compliance. Thumbs Up [/ QUOTE]
You're welcome I've heard a lot before, I've said things like that already
08.05.2020 21:07 # 7
f4t1hltn
But if their codes are different, do both brains adapt if they are removed from the gasoline vehicle? Or are the codes very important in this regard? Because I see only two serial numbers on the labels are different, and if you don't get it wrong, I see 2 brains leaving the same factory here :) and I can say that a price between 100-500 TL can be encoded. f4t1hltn 2019-01-10 15:37:41
08.05.2020 21:07 # 8
GokhaN
[QUOTE = f4t1hltn] But do they fit if both brains are removed from the gasoline vehicle even though their code is different? Or are the codes very important in this regard? Because I see only two serial numbers on the labels are different, and if you don't get it wrong, I see 2 brains leaving the same factory here :) and I said that the price could be between 100-500 TL for coding.
let's talk later let's talk again Smile
08.05.2020 21:07 # 9
f4t1hltn
Okay, okay :) Please see my ignorance exposed :) I have been struggling for 2 months 😀
08.05.2020 21:07 # 10
f4t1hltn
Brains turned out harmonious. The car works more comfortably than before, remote control, headlights, xenon headlights, taillights, indicators, indicator lights, date light etc. They all work. I had a problem with the heat, and thank God it was solved. Total software transfer and coding went 350 TL
08.05.2020 21:07 # 11
f4t1hltn
[QUOTE = gökhan]
08.05.2020 21:07 # 12
Levent206xt
What was the problem, you changed the brain.
08.05.2020 21:07 # 13
GokhaN
[QUOTE = f4t1hltn] [QUOTE = gökhan]
Come on, well done , someone who knows his job has done so that the price is pretty
08.05.2020 21:07 # 14
f4t1hltn
[QUOTE = Levent206xt] What was the problem you changed the brain. [/ QUOTE]
There was a temperature problem in the vehicle. The brain protected and stopped the engine within 4-5 km when the engine warmed up because it could not measure the engine coolant temperature precisely and it did not work for at least half an hour until the engine cools. the thermostat, the heat sensor changed, the wire was thrown into the sockets due to contact, but when it did not pass, it came out of the brain. Since it was a protective silicone-like substance inside the brain, it had to change because it could not be opened and repaired. I gave 450 TL for the brain, and coding and software transfer is 350 TL. Total 800 TL + labor costs. Thanks to the master, thank god we finished the job for 850 TL.
f4t1hltn 2019-01-15 14:16:27
08.05.2020 21:07 # 15
Orkunmmk0689
How did you get the brain?
08.05.2020 21:07 # 16
f4t1hltn
[QUOTE = Orkunmmk0689] How much did you get the right brain president [/ QUOTE]
As I said, I bought the brain for 450 TL, coding and software transfer 350 TL total 800 TL + workmanship 850 TL went.
08.05.2020 21:07 # 17
tsufrankwoli
Get well soon.
If you are in Ankara, can I find out where you have it built?
08.05.2020 21:07 # 18
f4t1hltn
[QUOTE = tsufrankwoli] Get well soon.
Yes, there is Yıldız Oto Elektrik in Şaşmaz in Ankara. Serdar master. Someone in Şaşmaz did not do the job and sends it to Serdar Usta.
08.05.2020 21:07 # 19
Levent206xt
Isn't it my capital industry
08.05.2020 21:07 # 20
f4t1hltn
[QUOTE = Levent206xt] No wonder my capital industry [/ QUOTE]
I guess it is the capital industry. On the way to Batıkent, on the street on the right.
Page : / 2
