Are the transmission oils different from the engine oil?
08.05.2020 17:30 # 1
Are the transmission oils different from the engine oil? Or do we put motor oil in your transmission?
What are the characteristics of the transmission oil for 206 1.4 petrol? How many liters? Thanks.
08.05.2020 17:30 # 2
No dear, will it be the same? The transmission oil is thick.
For example, you are using engine oil 5W-40 in your vehicle. The transmission oil is 75W-80. How many liters you get depends on how many liters you can filter.
08.05.2020 17:30 # 3
I know it won't be the same either. Some don't write it as a transmission oil on top. I asked him so. In the user manual on the site it says 75w-80. Is it true, hodja? Is it suitable for 206 1.4 gasoline? 99 models.
08.05.2020 17:30 # 4
Also let me ask about the crowd. Does Dot 4 as brake fluid "? Thank you.
08.05.2020 17:30 # 5
emre_akdag
[QUOTE = hLL 206] I know it won't be the same either. Some don't write it as a transmission oil on top. I asked him so. In the user manual on the site it says 75w-80. Is it true, hodja? Is it suitable for 206 1.4 gasoline? 99 models.
[/ QUOTE] yes you will put 75w80 oil bro. Transmission oil writes on the box, or a gear logo.
08.05.2020 17:30 # 6
emre_akdag
[QUOTE = hLL 206] Also let me ask about the crowd. Does Dot 4 as brake fluid "? Thank you.
[/ QUOTE] just like dot 4
08.05.2020 17:31 # 7
Burak
Of course, it is different. Transmission oil is another thing, engine oil is something else.
08.05.2020 17:31 # 8
mstf shn
DOT 4
08.05.2020 17:31 # 9
mstf shn
DIFFERENT ADMINISTRATION OF GEARBOX AND ENGINE OIL
5-30 FULLY SYNTHETIC OIL SUMMER IS COMING 10-30 YOU CAN USE IT
Transmission: 75-90
08.05.2020 17:31 # 10
SDYMZ
I recently changed the pressure pad, axle felts also changed, because the axle seal changed, the gearbox oil changed 75/80, put 2.5 liters. Sold as 1 liter including 17.5 TL VAT
08.05.2020 17:31 # 11
Thanks guys I took notes.
Transmission oil: 75W- 80
Brake Fluid: Dot 4
