appollotion fould
08.05.2020 15:26 # 1
komando
Hello, I have a 307 xt 2.0 hdi 2002 model vehicle, and it does the same fault with me. The car does not exceed 3000 cycles, but when it is in gear, it does the moment when you pull your foot off the gas. I changed it again, it took me to the brain repairer, he looked at the guy, he looked at it, there is no problem, they delete it, but he is doing the same again, he said that the brain will change lastly and as an error code (constantly malfunction when connected to the computer, he says control and surveillance failure) I am thinking of changing the brain share it, but it all stems from the brain
08.05.2020 15:26 # 2
komando
Does anyone know this problem?
08.05.2020 15:26 # 3
106_arts
they said it was the catalyst that made me this fault
08.05.2020 15:26 # 4
Apparently, this kind of problem has not been faced by anyone, it wasn't in the writer ... it is not a situation to be encountered very much. I hope it will be resolved cheaply ...
08.05.2020 15:26 # 5
metin
your vehicle is polluting the air malfunction, that is, it has caused a catalyst malfunction, but you said there is no catalyst in the diesel, I know there is a catalyst in all the vehicles.
08.05.2020 15:26 # 6
BAHTIYAR
If the catalyst is dismantled, it also has an antupollution fault fault, but it has nothing to do with the 3 thousand revolutions of the pull. If there is a catalyst and it is destroyed, the vehicle does not have enough air out.
08.05.2020 15:26 # 7
flash296
Have you looked at the pilgrim turbo? the malfunction is like a turbo malfunction ... everything will be nuisance in turbo malfunction, but the car does not exceed 3 thousand cycles .. if you want to have a look!
08.05.2020 15:26 # 8
metin
[QUOTE = flash296] dude did you look at the turbo? the malfunction is similar to the turbo malfunction ... everything will be in turbo malfunction, but the car does not exceed 3 thousand cycles .. if you want to have a look! [/ QUOTE]
sensible.
