Appearance Question about 206s
08.05.2020 14:18 # 1
kuhi
Hi guys, I think of buying 206, and of course a little bit of modification :)
but to me, I look at the advertisements that make the car a car rim and tires but I have seen something in the 206s. Even the same model in 206's, the clearance between the rear fenders and the tires is different, as can be understood in a different picture. Is every 206 changes produced or can we lift this fender part up?
Like this
1. The distance between the mudguard and the tire in the picture is very good
In the second picture, almost the fender tire is not half covered
kuh the 2010-07-04 13:06:58
08.05.2020 14:18 # 2
muhlisoz
interesting!! I did not examine the car in such detail ??
the photo may be due to shooting
or something that weighs in the trunk Dil Çıkarma
I do not know about it but maybe it is due to the model difference like xt xs
08.05.2020 14:18 # 3
SahinGun
There may also be a difference from the spring.
08.05.2020 14:18 # 4
kuhi
It has nothing to do with the picture angle, there are 3 206 in one thousand and X-line at 3, but when someone asked them, they said they got second hand and when they asked, they said that they got second hand,
it's a very small detail, but I still love what's above and when I think about buying a car, when I look at the cars, most of them are down, if we can remove these dumped fenders, I plan to buy a 206 this month,
08.05.2020 14:18 # 5
SahinGun
The subject you are talking about is about torsions. The torsion may have been lowered, if it is such an issue, you can remove it ...
!! In order to get a faster answer, it is useful to open a topic introducing yourself to our members.
08.05.2020 14:18 # 6
MirakGTI
In the second picture, the shadow was formed, perhaps the handbrake was not applied to the vehicle.
If torsions played, it doesn't.
08.05.2020 14:18 # 7
elenor
could the car in the first picture be from the roland garos model?
08.05.2020 14:18 # 8
EminONAL
1. spring is attached or not.
Played with a 2.tortion setting.
The 3rd hand brake is applied or not.
except for these reasons, all fabrication is at the same height.
08.05.2020 14:18 # 9
Kifanhom
[QUOTE = EminÖNAL] 1st spring is attached or not.
I agree
08.05.2020 14:18 # 10
ibrahim YILDIZAK
[QUOTE = sahing a]
There are no springs at the back of the 206's. There is torsion.
08.05.2020 14:18 # 11
EminONAL
When you put on a bow, you already have to play with the back like the "bird series".
Şahin meant him.
08.05.2020 14:18 # 12
SahinGun
[QUOTE = EminÖNAL] When you put on a bow, you are already obliged to play with the back like a "bird series".
Şahin meant him.
+1
08.05.2020 14:18 # 13
peugeotefe
If the torsion has been removed before, they may not have kept their original height.
08.05.2020 14:18 # 14
Melih
when I apply the 206 xt handbrake as in the 2nd picture when I release the handbrake as in the 1st picture Gülme
08.05.2020 14:18 # 15
kuhi
Thanks a lot for the information,
What about lifting the torsions, that is, standing high as in the first picture, creates a safety problem in the car?
08.05.2020 14:18 # 16
EminONAL
It does not cause any problems.
Remember that the closer the car is to the ground, the higher the risk of skidding at high speeds and bends. eminönal 2010-07-06 09:44:20
