Anything happened to you before :(
08.05.2020 18:11 # 1
307imbenim
Friends 3 days ago, my car was not working at 1-2, but it was blowing at 3-4 settings, and now it only blows at the 3rd setting, do you think what is the problem or waiting for your comments thank you ...
08.05.2020 18:11 # 2
Heating engine or control control. The solution in both of them is not less than 250.
08.05.2020 18:11 # 3
307imbenim
Is there so much master :(
08.05.2020 18:11 # 4
Unfortunately. You can ask my electrician if you are coming to Istanbul from the company that is the sponsor of the site alone.
08.05.2020 18:11 # 5
307imbenim
No, I live in the army, it is not so important to build an electrician :(
08.05.2020 18:11 # 6
307imbenim
Clima said that the key is broken, master quit or if there is a place where we can find the key, please help. :(
08.05.2020 18:11 # 7
307imbenim
actual
08.05.2020 18:11 # 8
It came to me, teacher. But I did not spend 250 lira, nor did the keys change. The trouble was in the cables, I made it for 20 liras.
08.05.2020 18:11 # 9
307imbenim
They are saying how they can be damaged from the ground when the cable was on the ground, and it was a distressed cable. I am very uneasy about this :(
08.05.2020 18:11 # 10
I don't know my teacher, I left it to the private service and the flow meter would change and I asked them to do it for maintenance, they said it was on the cable. I think it was contactless. It was quite. Don't worry about it. Just let the master eat you.
08.05.2020 18:11 # 11
307imbenim
Thank you. Let me have a little bit of water.
08.05.2020 18:11 # 12
rizeli_53
I think a solid electrician can handle it
08.05.2020 18:11 # 13
307imbenim
I'd take it to someone else.
08.05.2020 18:11 # 14
307imbenim
UPDATED
08.05.2020 18:11 # 15
I have the same problem now;
Workaround: When you turn it to 1 or 2, you will press the arm slightly. I think the style of non-contact is a problem
dogan106 2014-01-12 21:37:27
08.05.2020 18:11 # 16
Mustafa-almanya
In my clio room, there were occasional discontinuities and occasional discontinuities, I researched a little, and in clio, there was a situation in 1 and 4 positions, and 2 and 3 positions. your situation looks like him. Clios have a piece called solution German vorwiederstand, would it be from it. A large socket, which is attached to this part, enters the engine in a small socket that comes out of this part. Your situation looks very much like this. I changed it, but mine didn't work because if it works, it works at all levels, if it doesn't, it doesn't work at all levels.
I think this part of the link in the Peugeot 308
http://www.ebay.de/itm/kuhlventilator-widerstand-1308cp-peugeot-307-308-3008-5008-partner-1-6i-1-6-hdi-/330934729583?pt=de_autoteile&hash=item4d0d3f3b6f
08.05.2020 18:11 # 17
Mustafa-almanya
Do you sleep the track at 307, now I saw
08.05.2020 18:11 # 18
307imbenim
THANKS I WILL DO A RESEARCH.
08.05.2020 18:11 # 19
307imbenim
UPDATED.
