Antipollution Faulty (Solved) |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 207 | |
| 08.05.2020 19:37 | # 1 |
| 08.05.2020 19:37 | # 2 |
Brother, I think, don't worry about it, as we read in the forum, don't waste your money especially on LPG vehicles, don't waste your money and time, but if you have a performance performance in your car, shake it, I have 307 LPG. I asked you, do not worry about the lpg from the head, as you said, it gives more in cold weather, summer does not give for a long time
| 08.05.2020 19:37 | # 3 |
Efe-Pojo |
Exactly, if there is no problem in traction, consumption, do not worry. I've been riding with LPG for years, nothing has happened.
| 08.05.2020 19:37 | # 4 |
If only the warning comes out, I really don't care. However, the car runs jerky, does not eat gas. Because the masters fail, the motor protection is activated, so it says no gas.
| 08.05.2020 19:37 | # 5 |
My brother then could have been caused by a malfunction catalyst. Is there an explosion in the exhaust, the filter fiber filters in the catalyst are deformed over the years and do not throw away the gas that they burn and have problems in the engine vibration and acceleration.
| 08.05.2020 19:37 | # 6 |
Let me ask you about your confiscation. My Brnim vehicle, a 106 gti gasoline car, stacks up once and jumps suddenly after the first start, does not repeat any more, but does it once after each start. The engine does not matter whether it is hot or cold. Do you have any information, friends? Good luck with
| 08.05.2020 19:37 | # 7 |
Guys, I also showed your exhaust and catalyst today. 'There is no problem with them,' said the master. Let's see what happens next time I go to the service tomorrow.
| 08.05.2020 19:37 | # 8 |
Problem solved. I could not find an opportunity because of my busy work. 1 week ago I left the car to Vatan Peugeot. During the day, the ignition coil and socket changed. Also, when I bought the car, there was chemical water in the car instead of anti-freeze, and I did not notice and burned the gasket. He also looked at the master valves because the valve settings could be very tight and my car has not opened a fault record for 1 week.
| 08.05.2020 19:37 | # 9 |
sonerkyl |
[QUOTE = pharuq] Problem solved. I could not find an opportunity because of my busy work. 1 week ago I left the car to Vatan Peugeot. During the day, the ignition coil and socket changed. Also, when I bought the car, there was chemical water in the car instead of anti-freeze, and I did not notice and burned the gasket. He also looked at the master valves because the valve settings could be very tight and my car has not opened a fault record for the following 1 week. [/ QUOTE] I'm glad to have your problem resolved.
