ANTİPOLLUTİON FAULTY ERROR
08.05.2020 21:11 # 1
serkan066066
PEUGEOT 207 1.4 HDI TRENDY MY VEHICLE GIVES AN ANTIPOLATION ERROR AND THERE IS NOT 3,000 PERIOD. I USE THE INJECTOR CLEANER FOR THIS, BUT IT STARTED NOT TO BENEFIT. WHAT SHOULD I DO?
I TRY TO CLEAN THE VEHICLE ON A LONG ROAD WITH 3 THOUSAND PERIODS THERE
08.05.2020 21:11 # 2
74emre
Take out the injectors and see if I had the same problem. The breast of one of the injectors was clogged. Suanlik no problem. They injure the problem.
08.05.2020 21:11 # 3
First of all, there are two reasons when you are welcome.
08.05.2020 21:11 # 4
serkan066066
IS THE INJECTOR REMOVAL SET SIMPLE? Does it take time? WHAT SHOULD I SPARE BUDGET FOR CLEANING?
08.05.2020 21:11 # 5
Serkan brother is not very simple, he should do a biken. The average varies between 500-1500 TL depending on the condition of the injectors. If you have a master problem, I will help you get information and price.
08.05.2020 21:11 # 6
serkan066066
I am in Ankara. I THINK THAT IT WOULD HAVE BUT IT HAS BUT SOMEONE KNOWING DIAGNOSIS BETTER BETTER. THE CAR IS CONTINUOUSLY LIGHTED ON AND DOES NOT HAVE 3 THOUSAND PERIODS. I HAVE 10 THOUSAND MAINTENANCE IN THE PAST. I CHANGED THE FUEL FILTER. He was a few days back to normal.
08.05.2020 21:11 # 7
Is there any original software in the master? I looked at the peugeot master injector values from the computer.
08.05.2020 21:11 # 8
serkan066066
NO NOT LOOKED
08.05.2020 21:11 # 9
serkan brother first of all, the original software has to be looked at, the problem is that the injectors do not have anything else or the original software is not in the hands of the master. ivedik mas mas peugeot have abdullah master go take a look get price in the original software in hand and look at injector values and error codes.
https://www.google.com/maps/place/Mas+Service/@39.9921713,32.7629974,17z/data= ! 4m6! 3m5! 1s0x14d34a2bc19671d7: 0xc0321bcd29dec170! 4b1! 8m2! 3d39.99266996286286286886! hl = en
mobile phone of the master: 0537 796 58 20
sonerkyl 2019-03-22 12:28:40
08.05.2020 21:11 # 10
serkan066066
Thank you. It looks like the end of the week will be. I will share the detailed information.
08.05.2020 21:11 # 11
serkan066066
HELLO THERE.
INJECTOR FAILURE IS SOLVED BY USING CLEANER. BUT THIS TIME THE CAR IS PASSING 3,000 THOUSAND PERIODS, BUT I WON'T FEEL THE INDUSTRY. THEY PRINTED THE PAD. FOR HIS, THE TRANSMISSION WAS DOWN. I SPENDED 1500 TL MONEY. BUT STILL COME SOUND FROM THE TRANSMISSION. WHEN I ASKED THIS TO THE MASTER, THIS TRANSMISSION HAS BEEN FROM THE GEAR GEAR. I DON'T KNOW HOW MUCH AMOUNT
08.05.2020 21:11 # 12
serkan brother where did you get the procedures done. I am very bro for changing the 1500 TL printing ax. If the injectors are removed, cleaned and adjusted, I can say normal for both. What brand of parts were used. gear repair can still exceed 500-600 rubles.
NOTE: Capital letters are forbidden due to forum rules. Smile
sonerkyl 2019-03-26 09:50:16
08.05.2020 21:11 # 13
serkan066066
As soon as I got the car, I did not have a car there, but I made it there as a master of my father.
the gearbox has landed and washed.
The printing has changed to the pad. It is called clutch kit.
prizdirek guide changed.
axle seal right left changed
transmission oil was added.
front brake pad changed.
The part of these transactions kept the original 935 TL.
It took 300 labor.
When I say small pad spray, setting or something, I went up to 1500.
08.05.2020 21:11 # 14
I think they bought a lot, serkan is normal for these processes, but the prices of other parts are very expensive. Let me tell you, there is no guarantee for the original parts installed outside the authorized service.
print set = 500 tl
prizdirek = around 60-70 tl
axle seal single = 40 tl
liter of chassis oil = 40 tl 1 liter was added.
front brake pad = trw 95 tl
max. prices. They bought 300-400 rubles more than you. Anyway, good friend now. Just keep in mind, contact me about spare parts and we will resolve the prices.
08.05.2020 21:11 # 15
serkan066066
Let me tell you the parts prices.
print set 525
socket guide 35
axle seal 35-35 70 tl
gearbox oil 120tl 3 lt
original front lining 185 TL
08.05.2020 21:11 # 16
serkan066066
I bought unbelievable auto from aykan pejo
08.05.2020 21:11 # 17
Except for pressure, prices are not bad. No need for the front ax, I have bought 4u (German made) or trw brand for years. no crowing etc. I did not have a problem in my vehicles. The price comes in half.
08.05.2020 21:11 # 18
serkan066066
What is the price of gear in this transmission, including craftsmanship? the car is also making noise and there is a slight tremor.
08.05.2020 21:11 # 19
Well, if you look at the engine chocks and injector situation, my teacher had trouble like you, the friend was going to change the pressure. I would like to connect to the computer and look at the injector timings and pressure conditions.
