antipollution fault warning and catalytic converter
08.05.2020 17:58 # 1
dr.ali
This morning, after starting the vehicle 150-200 mt, he stopped while getting up at the lights. When I run it again, the engine sign was on the display screen and it gave antipollution fault warning and catalytic converter fault warning. Vehicle shake at idle. In this state, I traveled 6 km. I parked the car, stopped the engine, started it again, there is no warning or jolt. I went 10 km until the mechanic in Zeytinburnu. It did not warn or the lamp did not light up. There was no jolt at idle. The repairman said, "Let's see if the lamp is on, let's change something now, we would have made expenses. Come when it makes a shake that it gives error."
I have a problem in taking over, although I have sometimes rooted the gas since I bought the car. In addition, even when it is cruising, even when it is at a sufficient speed, when I pull my foot out of the gas (no matter how slow I pull my foot) it loses shaking and cycle. The same cycle loss and shaking are also experienced when pulling from the clutch. I am experiencing this shaking and cycle loss even before the engine is warming up. Or when I get into congested traffic. But sometimes he gets up as if he has no problem. (My wife says I use other vehicles very smoothly, I can not use my own vehicle :))
307xs 2004 model 83bin. air oil filters changed one and a half years ago. There was no need to change the control 6 months ago, it was said to be good.
Is there any harm in using it like this, as the mechanic said? or why is this all about?
08.05.2020 17:58 # 2
you http://forum.peugeotturkey.com/forum_posts.asp?tıd=7516&title=yeni-yelerin-dikkatine-konu-amadan-oku
First of all, if you introduce yourself to this link, we can provide a more useful share.
Also, I think the oil filter needs to change every time the oil filter changes, I think the oil filter and the air filter are also replaced by the antipollution fault warning.
Alper`EN AKSU 2013-10-02 15:02:44
08.05.2020 17:58 # 3
fexzi
German means you pollute the environment: D
08.05.2020 17:58 # 4
dr.ali
I think you suggest filter replacement for antipollution warning.
When I first bought the vehicle a year and a half ago, I took it to maintenance and replaced the filters at the authorized service. The problems in the second paragraph have been going on for a year and a half. Will filter replacement be sufficient for these problems?
08.05.2020 17:58 # 5
I think it will be enough or you can take it to a good master. If you are on the European side, I can help.
