Antipollution fault in diesel.?
08.05.2020 17:07 # 1
fatihgg
Greetings
Friends I have read a lot about this in the forum, but all of them are also lpg cars. I have 2003 1.4 hdi 307. I am going to connect to ppye tomorrow. How could I feel so enjoyable in the evening? > 2012-11-02 19:04:57
08.05.2020 17:07 # 2
nupel307
it came to my press..kardes in my car the tank was under a quarter tank, i went, i added fuel, it improved .. i have read in many places, this problem may be caused by leaving less fuel in the tank.
08.05.2020 17:07 # 3
KenBlockJR
Is it over 3000
08.05.2020 17:07 # 4
blinddark
In my car, 2003 307 1.4 hdi, I approached the fountain with the last car, stopped the car, parks were near and the tape was hungry, got out of the car, washed my hand (on average 5 minutes), came, started the car, gave this error, I immediately called in the booklet, but I could not find this error, it happened on the 18th of October but it was I haven't had any trouble since, or have not seen that error a second time
08.05.2020 17:07 # 5
adali
I occasionally get that error, but nothing important happens. gives the same error from different things. don't bother so
08.05.2020 17:07 # 6
fatihgg
Generally, there is not much fuel in the warehouse, my rarity is 50-100tl room, I take it close to the quarter quarters, but I hope it is about diesel, I have been using shell gtl for about 4 months. , oxygen sensor, air filter, diesel filter, there is a small air filter under the air filter, there are hundreds of errors. I look at it, but it is not a normal fault-clearing device, not pp. Some of them say a few days, no problem in the vehicle, the noise is normal for 3000 rpm. The sound is normal in the engine.
08.05.2020 17:07 # 7
nupel307
Do nothing, just take a little fuel.
08.05.2020 17:07 # 8
fatihgg
Let's assume what it is about fuel, why not? What is the meaning of this malfunction?
08.05.2020 17:07 # 9
impact
If your brother has a heavy situation in your head, the car will shut itself down.
08.05.2020 17:07 # 10
fatihgg
Emrah I got a hair or something :) Of course, somewhere there is a malfunction.
08.05.2020 17:07 # 11
berk2309
When the errors are received, the necks are generally used for 5 to 10 minutes at high speed and burn the institution inside. & nbsp; if it does not improve, then they look at them. & nbsp;
08.05.2020 17:07 # 12
fatihgg
[QUOTE = berk2309] usually, when this error is taken, they let the institution run the high speed for 5 10 minutes and burn the contents in it.
Let's see if I use a high speed tomorrow tomorrow. Well, it is not necessary to filter the malfunction at every chance.
08.05.2020 17:07 # 13
berk2309
to the best of my knowledge & nbsp; It is necessary to make it clear:) & nbsp;
08.05.2020 17:07 # 14
fatihgg
Nette egr valve they call 90tl filer :) I do not know what the original liner is, I do not know what the tab is, etc. What did you say?
08.05.2020 17:07 # 15
fatihgg
Do not ask, my head is disastrous.I did not get over the traffic, then I would go out and get out :) I wouldn't sleep at night. It will take heat to take the pressure. Do you need to listen to the words of my grandfather? My father says always son, do not let the car fall under a quarter :))
08.05.2020 17:07 # 16
berk2309
soner with great chance, but the brain remains malfunction, I guess & nbsp; nickname or nothing as a record & nbsp;
08.05.2020 17:07 # 17
nupel307
I had come to my press because of the low fuel ... I bought the fuel, it was not any more ... I searched a little bit. If you use the tank under the quarter, there are such problems.
08.05.2020 17:07 # 18
fatihgg
I came from outside, I used the car over 3000 degrees and over, I came for 20 minutes or so, no sound, etc. There is no problem in the light, the light is still on.
08.05.2020 17:07 # 19
fatihgg
[QUOTE = 307 bursa] ah be fatih so dont worry about it don't fill the tank tomorrow without clearing the error i think:)
how the bidet sounds after 3000 cycles, how does the exhaust sound but twill :)
Tuesday hic its taste I did not hear your voice, I thought I had a bit of trouble. Tomorrow, I was going to make a mistake after the benzine.
& nbsp; ..?
08.05.2020 17:07 # 20
impact
[QUOTE = fatihgg] Do not ask me, my head is disastrous. I did not get too heavy, I got a lot of traffic, then I got out of the window :) My bed was at night. One day it would be difficult to print 50 50 diesels. Is it necessary to listen to big words? ha & nbsp;
Page : / 2
Peugeot Forums - Peugeot Fan Club © 2025
FromOwner.co.uk — Buy & Sell Directly from Owners in the UK. No dealers. No commissions. Just from owners.
