antipollution fault error
08.05.2020 21:29 # 1
ozandemir34
Friends, I took my 2005 model 1.4 hdi 307 vehicle, which I have been using for a year and a half, to maintenance in January. 2 weeks after the maintenance, when I was driving with fixed gas in the vehicle, I started to get 2 3 seconds gas cut off instantly, yellow engine fault light and antipollution fault error on the screen. I got the same error for 2 weeks on a 20 km road where I went daily. After that, I did not encounter this error for 2 months, but for the last 1 week, this error has been encountered. When I pull my foot out of the gas and press it back, it gives this error and does not eat gas. It is not a frequent event, but it is still annoying. After all, I want to sell the vehicle tomorrow, but I do not want the other side to call me because of such a problem.
Does anyone know the exact solution to the problem, because as far as I research on the internet, people complained that they couldn't change other parts and find solutions, but unfortunately I don't have any material to change every part. I know that scuba vehicles are also constantly encountered, but it is interesting to have such a mistake in diesel. I always buy fuel from bp, I believe it's clean.
08.05.2020 21:29 # 2
The reason for this is the fact that the vehicle is always used for a short distance. I think change where you are fueling. Get 10-15 krs more. shell is good at this. Use the vehicle in a suitable place at low speed and high speed. if possible, try not to drop the tank below a quarter.
08.05.2020 21:29 # 3
ozandemir34
Thank you. I had this in my mind, but I was not sure, I hope I will apply what you say in the evening at a suitable time. Smile
08.05.2020 21:29 # 4
ozandemir34
Edit: As you said, I took the fuel from the shelter and pulled it over the half tank and I drove the vehicle for about 5 minutes at 3500 revs, I have been driving the vehicle for two days and I have not encountered the same problem. Thank you for your information.
12.06.2020 13:58 # 5
ozandemir34
I resumed getting the Annipulation fauld error 3-4 times on a 10 km road. The error is like this, while your foot is on the gas on the road (idle or when I press the brake, it did not work), the faucet sign suddenly appears on the vehicle screen, it says annipulation fould and the vehicle was officially collapsing. When you pull your foot from the gas and press it, it was sensing again. I threw Würth injector cleaner and drove 100 km at 4th gear, but the problem did not resolve. The warehouse is not always below half. On a page I came across on the Internet, with the recommendation of a friend who got this error in the same way, I pressed the brake with the other foot at the same time while giving gas at low speed and the same error appeared on the screen. He said that the reason for this was due to the oxidation of the brake switch. I sprayed the ignition and cleaned the brake light, but it gave the same error again. I bought a new one from the industry for 45 TL and installed it again in two minutes. Thank goodness it doesn't give this error anymore. I hope there are other friends who have received the annipulation fauld error like me and they can get rid of the problems by trying this way as I mentioned. I tried it directly without connecting it to the computer because the problem was the same and it was fixed. ozandemir342020-06-12 14:09:46
