Antipollution fault error !!!
08.05.2020 19:47 # 1
Utkukaraca67
Friends, this tool is hurting my head. I changed injectors yesterday. I got the injector out. I traveled 35 km and there was no problem. Today, I used the city, there was no problem, but when it was around 150 in 5th gear, it gave antipollution fault error. As if the draw fell a little. Help me, what was this engine in?
08.05.2020 19:47 # 2
Your vehicle was gasoline, diesel
08.05.2020 19:47 # 3
Utkukaraca67
Diesel
08.05.2020 19:47 # 4
Halil5759
2 months ago, he gave the same mistake in my car, but there was no problem in his drive when he was driving, after a little research, I used it for 10 minutes at about 10 km 3000 rpm and stopped, and after half an hour, I restarted the car and stopped immediately. I did it 4 times and when I run it 15 minutes later it was improved. Thank goodness for now.
08.05.2020 19:47 # 5
Utkukaraca67
I think it may be due to fuel
08.05.2020 19:47 # 6
Bha41
My vehicle made the same mistake. So, while the fuel light was on, I went up and down for a little while. The light started to burn. I fulled the tank and threw a wurth injector cleaner. It was a little over 100km long. By the way, I threw the wurth for black smoke.
08.05.2020 19:47 # 7
Utkukaraca67
I also have black smoke. This error happened when my light of light was on
08.05.2020 19:47 # 8
Bha41
Hodja, the horse did not cut 100km a little later, the warehouse is almost close to completion.
08.05.2020 19:47 # 9
ARDADOGAN
If the brothers fell out of traction when it means writing engine malfunction probably egr last time when you cleared it will affect the traction egr
08.05.2020 19:47 # 10
Utkukaraca67
I just bought the car tomorrow and let me see
08.05.2020 19:47 # 11
Bha41
We look forward to improvements
08.05.2020 19:47 # 12
Utkukaraca67
Ok let's see
08.05.2020 19:47 # 13
Utkukaraca67
I erased the fault and it seems like there is no problem at the moment. However, when loaded on the gas, black smoke is released. It's not intense, but it gets stuck in my head. Tyrbo had lubricated hose, and I installed another long hose. But below, insert the turbocharger into a slightly broken part. This hose expands when the gas is pressed. I wonder if the black smoke restricts the attraction of the turbo?
08.05.2020 19:47 # 14
Bha41
Turbo will also be baked on Monday. Black smoke is also available to me ..
08.05.2020 19:47 # 15
Utkukaraca67
When I ordered whürth, I will throw it to the vehicle. Whürth changed the voice of the car
08.05.2020 19:47 # 16
Bha41
I did not pay much attention afterwards but my vehicle does not work very loudly
08.05.2020 19:47 # 17
ARDADOGAN
If the catalyst is clogged, it will make me empty it.
08.05.2020 19:47 # 18
Deniz44
I have a vehicle with 2005 307 xt petrol + lpg.
08.05.2020 19:47 # 19
akyuz.cagri
I am also giving the same error to my friends ... I am also having the problem of stopping while driving. The car stops but the hydraulic is not deactivated .... I pull it over and start it again ... The engine light keeps on ...
08.05.2020 19:47 # 20
Deniz44
Well, my teacher said that if there is no problem, I will give my vehicle because of gasoline + LPG LPG. In the pursuit of your pocket, the nation will not care about how they will earn this money, some arc will be angry but bole trades
Page : / 2
