"antipollution fault" error ...
08.05.2020 16:31 # 1
Dostum
hello ... 307 1.6 hdi start my vehicle at 7-8 degrees in the evening and 50 meters ahead & nbsp; I waited in the red light ... after the outside, the word "antipollution fault" and the "valve" shape appeared on the vehicle indicator ... approached 5 km, the fault lamp still did not go out ... there is no low speed of the vehicle's & nbsp; traction, acceleration ... I use unbound in it. Under 2000 cycles, will this be negative? What is the malfunction ...
08.05.2020 16:31 # 2
Alicilik
The first time I ran it last morning, it gave me the same warning, but I stopped and restarted and it improved.
08.05.2020 16:31 # 3
acd org
that post spontaneously a few days soner & nbsp; do you usually drive the car under a quarter tank? it happened to me a few weeks later the pump failed & nbsp; I changed it when I was idle, the right sound was coming from the back a very light sound from the pump ... when you switch the bidet contact & nbsp; the gas pump is gone while the car pump is pulling gasoline without running the car & nbsp;
makes a few mistakes.
Reviews
08.05.2020 16:31 # 4
Dostum
in other forums they said very different things for the same problem. For example, the exhaust sensor may be broken ...
08.05.2020 16:31 # 5
Dostum
Meanwhile, the car was in a quarter warehouse ...
08.05.2020 16:31 # 6
erkerd5429
the same light intake manifold pressure sensor failure in my car comes out but my car is scuba
08.05.2020 16:31 # 7
Dostum
Hi Friends ... Today, the "antipollution fault" error in my car and the valve shape on the indicator have gone ... At least 5 times in a car's manual "not to be lower than 60 km speed & nbsp;" minutes, drive your car, show it to the service if the error is still going on, "he said, even though I was not 60 km, I drove it for about 10-15 minutes at 2000 speeds and above, then thank you very much. , I told the incident, it was caused by the use error, I should not use the diesel vehicle without revolutions, whether the vehicle is 2nd or 3rd gear but do not fall below 2000 revolutions, do not move immediately at the first start, do not turn off the vehicle before stopping, too ...
08.05.2020 16:31 # 8
06OzGuR06
[QUOTE = Dude] Hi Guys ... Today, the "antipollution fault" error in my car and the valve shape on the indicator have gone ... "This error can be in low speed use and & nbsp; city traffic, not less than 60 km speed." drive your vehicle for at least 5 minutes in cycles, show it to the service if the error is still going on. ” I called my own pejo master & nbsp; I explained the incident, it was caused by the error of use, I should not use the diesel vehicle without a cycle, whether the vehicle is 2nd or 3rd gear but do not fall below 2000 cycles, do not move immediately at the first start, do not turn off the vehicle before stopping, too. .. [/ QUOTE]
I agree exactly with the master said. "Wink" Reviews
08.05.2020 16:31 # 9
yavuz25
[QUOTE = 06ÖZGÜR06] [QUOTE = Dude] Hi Friends ... Today, the "antipollution fault" error in my car and the valve shape on the indicator has gone ... "This error can be in low speed use and & nbsp; city traffic in the car's manual, 60 km drive at least 5 minutes, not to be slower than the speed, show it to the service if the error is still continuing. " Thank you very much the shape disappeared. I called my own pejo master & nbsp; I called, told the incident, it was caused by the use error, I should not use the diesel vehicle without a cycle, whether the vehicle is 2nd or 3rd gear but do not fall below 2000 cycles, do not move immediately at the first start, also before stopping the vehicle do not close heman, he said ... [/ QUOTE]
I agree exactly with the master said. "Wink" [/ QUOTE]
rules to consider. "Wink"
yavuz25 2012-01-04 22:02:46
08.05.2020 16:31 # 10
Dostum
I've used gasoline for years ... I think it will take some time to get used to the diesel ...
08.05.2020 16:31 # 11
yavuz25
[QUOTE = Dude] I've used gasoline for years ... I think it will take some time to get used to the diesel ... [/ QUOTE]
never ask my brother. I have the same situation in me.
08.05.2020 16:31 # 12
Dostum
Hi Guys ... Today, when I was overtaking a car in & nbsp; city traffic, I stepped on the gas a bit & nbsp; and again "valve shape" appeared on the dashboard and wrote " antipollution fault" error on the road computer ... "I went to pejo master," planet 2000 "program has entered the ecu and detected" egr valve "malfunction ... The master egr valve & nbsp; is expensive, the institution may have connected it, the people before you may have connected exhaust and valve soot due to poor quality fuel, clean diesel & nbsp; said, "We added a contribution to the diesel tank" engine silk "... deleted the fault from the system, said that if it repeats it will remove and clean ...
& nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; I wonder what is this "egr valve", where is it, video or picture, can I disassemble it & clean it to remove and clean it ... can you help ... Regards ...
08.05.2020 16:31 # 13
should be .. egr valve & nbsp;
cigdemilker 2012 -01-07 23:28:26
08.05.2020 16:31 # 14
[QUOTE = Dude] Hi Guys ... Today, & nbsp; while I was overtaking a car in city traffic, I stepped a little too much & nbsp; and again wrote "valve shape" on the dashboard and wrote the error on the road & nbsp; " antipollution fault" ... Pejo master I went, entered ecu from "planet 2000" program and detected "egr valve" malfunction ... Master egr valve & nbsp; expensive, institution may have connected, people before you may have exos and valve connected due to poor quality fuel, clean diesel & nbsp; said, "We added a contribution to the diesel tank" engine silk "... deleted the fault from the system, said that if it repeats it will remove and clean ...
& nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; I wonder what is this "egr valve", where is it, video or picture, can I disassemble and clean it to remove and clean it ... can you help ... Regards ...
Egr information about: http: //www.obitet.gazi .edu.tr / obitet / exzoz_sistemi / erg.htm
You can decide for yourself whether you can watch the video or not.
[TUBE] xm9usadqmuo [/ TUBE] Reviews
08.05.2020 16:31 # 15
cinecommentator
[QUOTE = acd org] that post spontaneously a couple of days soner & nbsp; do you usually drive the car under a quarter tank? it happened to me a few weeks later the pump failed & nbsp; I changed it when I was idle, the right sound was coming from the back a very light sound from the pump ... when you switch the bidet contact & nbsp; the gas pump is gone while the car pump is pulling gasoline without running the car & nbsp;
makes the error a few things 2 3 days, I say go to a service ...
exactly..my usually heppppp quarter tank or below..for gas firing cost..now now When my car was especially cold..when it was working..they said gas pump..and also & nbsp; `` antipollition fault`` is going .. mileage indicator when the car is running, a tap shape appears 20 thousand or so ..
< br>
I have read dozens of articles about this error almost anyway..nigh relatives and symptoms similar to mine have been quoted above I was your friend
08.05.2020 16:31 # 16
Dostum
Mr. Moderator. In the link you sent, there is a plain text description about "egr system" ... I did not see a video ... Regards ...
08.05.2020 16:31 # 17
[QUOTE = Dude] Mr. Moderator. In the link you sent, there is a plain text explanation about the "egr system" ... I did not see the video ... Regards ... [/ QUOTE]
The video is just below the post. Link to:
http://www.youtube.com/v/Xm9uSaDQmuo&rel=0&hl=en_US&feature=player_embedded&version=3
08.05.2020 16:31 # 18
Sometimes it turns out in me, it disappears when I stop and run it again :) I think there is an instant fault :) because it was connected to the computer in the service recently. There was no fault code.
08.05.2020 16:31 # 19
cermiki
The same thing happened to me in the summer. The reason is dirty diesel. First, have a look at the diesel filter. it may be clogged. If the problem is not in the filter, it may be yours.
08.05.2020 16:31 # 20
Dostum
Dear Member ... I could not understand the failure of the egr valve with the diesel filter ... Also, what you mentioned about the sender is what the sender is ... no problem in the vehicle's traction or fuel, it gives "antipollution fault" from sudden accelerations ...
Page : / 3
