Antipollution Fault Error |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 207 | |
| 17.06.2020 10:54 | # 1 |
| 17.06.2020 10:57 | # 2 |
sonerkyl |
Possibly the injector is clogged or there is a loose contact in the cables. It is necessary to check the coil and spark plug, disassemble and clean the injector.
| 17.06.2020 11:30 | # 3 |
I want to replace the coils and spark plugs with the originals. 1.4 Is Injector expensive for gasoline?
| 17.06.2020 14:18 | # 4 |
sonerkyl |
One injector is expensive, sir, an average of 150-200 TL.
| 17.06.2020 18:10 | # 5 |
Hello, the same problem happened to me in my 2009 1.4 diesel 207 vehicle, I use it like this for about 1 month, the first time I bought the fuel showed this failure the next day, I probably use it because of the dirt in the fuel, I use it this way I will go to the mechanic these days ist beylikduzu good master If you recommend, I can work
| 17.06.2020 18:36 | # 6 |
A similar problem just happened to me, it stopped when the gas was pressed and was throwing white smoke, the master looked at the injectors, the direct injector nozzles were changed, I gave 1600 TL in 4 parts.
| 19.06.2020 17:27 | # 7 |
It happened again today, it was raining when this problem first happened and it was raining today. Could it be touching the sensors etc.
| 27.10.2022 15:21 | # 8 |
I also had the same problem. I took it to the service, they changed all 4 spark plugs and the problem was solved. I thought 1 month later it gave the same error again. Let's see, as of now, I poured gasoline additive injector cleaner into the tank, I will try and see. By the way, in 1st and 2nd gear, the car cuts off the gas, it does not eat, I have no problem in other gears.
| 14.11.2022 12:19 | # 9 |
When I got this error in diesel 1.4, it was understood that the EGR was clogged and the electronics were broken. |
