"antipollution fault" error
08.05.2020 16:45 # 1
FTH
Hi;
My car gave an error of "antipollution fault" today. The engine malfunction lamp came on. I had gas installed in the car. Could there be a problem with this?
Thank you
08.05.2020 16:45 # 2
metin
Get past fth. Antipollution foult error is usually caused by oxygen sensors. The task of these sensors is to measure the air fuel mixture and deliver it to the brain. In this way, it provides the best combustion by adjusting the fuel mixture, which is more or less in the brain, according to the information given by oxygen sensors. & Nbsp;
is because it is. So the fuel is low and the mixture is not good, because the oxygen sensor is not good, it gives Antipollution foult error. With a small setting, your problem will be corrected.
08.05.2020 16:45 # 3
FTH
Thank you, my text, connect the LPG in the morning, went to the service, put out the light with the computer. >
Reviews
08.05.2020 16:45 # 4
FTH
On the way back home, he burned again: (what way do you think I should follow
08.05.2020 16:45 # 5
tilbe307
There is only one way to buy the LPG and your car from a regular place. Friends say this is from the lpg setting. so it was also burning in my vehicle. Now it is extinguished, it is not a very important fault. I made a full 30 thousand km with that breakdown. now extinguished & nbsp;
08.05.2020 16:45 # 6
efe1988
Usually if there is a gas setting of 40% or less, it does so.
08.05.2020 16:45 # 7
ismail ozdemir
ahhh ahhha ^^ pejo and lpg torture ^^
08.05.2020 16:45 # 8
toga406
There was a deceased brodway used in my father for 10 years. that air filter has not changed once. he wouldn't say to me on dusty roads. The deceased vehicle that absorbs the dusty-demolished air, puts it in the fuel and goes on its way.
08.05.2020 16:45 # 9
FTH
I'll take the tank out of a different place. & nbsp;
I'm going to go again today and open the settings a bit.
again, thank you ..
& nbsp;
