antipollution fault and catalytic converter fault
08.05.2020 15:09 # 1
blgnn2
Emergency help. I have 307 gasoline vehicles in 2004. It has not been 2 months ago. I traveled quite super 2 thousand km without any problem. but the car had a traction difficulty, especially on slopes. Then one day while driving in the traffic, the car started to shake and stopped while stopping at the red light. At that moment, at least 5 km on the road, the car stopped 10 times. vehicle on the slope. I parked the car in the garage and then said I would run it two days later, the car did not work. I called the master who installed the gas. LPG is not related to the job, you have the coils checked the ignition system. the tool works very hard, stops at home and writes antipollution fault and catalytic converter fault.
please help me. What should I do? In this case I am in Ankara. Do you have a master to recommend? is this caused by lpg? :S
08.05.2020 15:09 # 2
VEDATDINC
If it is working on gasoline and making lpg problem, lpg system is having problem. If it doesn't work on gasoline, you can connect it to the planet device and learn the problem clearly.
08.05.2020 15:09 # 3
BAHTIYAR
Talking with the master master helps you master http://www.anadoluosb.org.tr/tr/index.php/component/content/article/75-ticaret/346-selman-oto-servs.html?directory=77 HAPPY PERSON 2011-03-12 20:57:32
08.05.2020 15:09 # 4
touologist
I went into the service and went out with a similar problem today.) ... The spark plugs have changed and the butterfly has been cleaned.
Total penalty: 168 TL
The vehicle was giving both antipollution and convector error, 2004 envy triptronic vehicle at 66,000
08.05.2020 15:09 # 5
ismail ozdemir
this problem started to be in me pejo 307 2002 lpg appreciation has been a year when the car is hard to press on the hard gas, i dont collect it in the first time in the idle, i chose the car like this, i chose the spark plug and butterfly, i changed the spark plugs, did not fix it, you did not clean it, then you did not clean it, you did not tighten it, then you did not clean it, you did not clean it, then you did it.
08.05.2020 15:09 # 6
sedat23
[QUOTE = blgnn2] Emergency help. I have 307 gasoline vehicles in 2004. It has not been 2 months ago. I traveled quite super 2 thousand km without any problem. but the car had a traction difficulty, especially on slopes. Then one day while driving in the traffic, the car started to shake and stopped while stopping at the red light. At that moment, at least 5 km on the road, the car stopped 10 times. vehicle on the slope. I parked the car in the garage and then said I would run it two days later, the car did not work. I called the master who installed the gas. LPG is not related to the job, you have the coils checked the ignition system. the tool works very hard, stops at home and writes antipollution fault and catalytic converter fault.
please help me. What should I do? In this case I am in Ankara. Do you have a master to recommend? is this caused by lpg? : S [/ QUOTE]
There is a hardening in the steering wheel
