Antipollution Fault (307 XT Gasoline 1.6 Automatic)
08.05.2020 18:48 # 1
SOP
Hello, I am using 2004 model automatic 307 with
1.6 Petrol + LPG. I bought the vehicle 1 month ago. When using LPG, it gave antipollution fault error. I took it to a good master of Peugeot. LPG is damaging this vehicle, use it in gasoline, he said. I was doing it for 15 days. And the malfunction was gone ..
However, I completed the warehouse from opet 2 days ago. Although he was on gas after 30 KM, he gave an error again. It seems to me that the performance has changed a little .. Why is it doing this, how do we fix it?
Thank you ...
08.05.2020 18:48 # 2
65serdal58
I am having the same problem ...
It is a long time when I use it in gasoline. Whenever I use lpg, it is the same problem. I have stopped dealing with that problem. "middle" />
did not cause any problems with the towing of my car.
08.05.2020 18:48 # 3
SOP
Thanks, but now he started doing it on gas. I already have a problem, starting to do it on gasoline: /
08.05.2020 18:48 # 4
oktobus2
my friend also has XT 2003 model pejo, I have a lpg with atiker brand OBD. I have been riding for 1 year without any problems. I think there is a problem in the lpg brand. Although the catalyst is about to complete its life from time to time, I saw it in friends who gave the same error. you may have a catalyst. but when connected to the computer it indicates the catalyst error
08.05.2020 18:48 # 5
SOP
as far as I understand it could be something from the catalyst. Thanks
08.05.2020 18:48 # 6
aokaymaz
I bought the vehicle at 80000 km atikikler 2 years ago, and thank God it was not a problem, wherever I find it cheap, I get it from there. not aokay 2014-09-16 10:32:05
08.05.2020 18:48 # 7
ilker27500
It had been in my vehicle. When he connected the device, he gave the error of a piece called Air Pressure Sensor. I changed it to 70 TL at the same time, the problem went away and never happened again.
08.05.2020 18:48 # 8
SOP
Thank you very much .. I hope my problem can be done so cheaply. I will go to the master next week to clarify the situation. I share the result.
08.05.2020 18:48 # 9
My car was in 307 2005 euro diesel. said the catalyst may be from the master. It has been 2 years since I did not give the error. Big smile
08.05.2020 18:48 # 10
SOP
Interestingly, mine also improved this morning. I hope we see many smooth years Smile
08.05.2020 18:48 # 11
syz33
I have the 2003 model 307 1.6 XT Premium and I got the same error. It is not an important thing, let me say in the pipe that goes to the exhaust at the exit of the engine. Simple to clean it. Disassemble it to your mechanic, take it to the exhauster carefully, they heat and shoot in the flame of the oxygen source, and the dirt inside the body is pouring. I made this one-to-one simple, and it has improved.
08.05.2020 18:48 # 12
SOP
thanks, I'll have that look before the inspection;)
