antipollition fault help please
08.05.2020 17:59 # 1
muammer91
Slmlar everyone got me 2 weeks ago 2004 model 206 1.6 xs I am very pleased with the car :) but when I was on the road last week, I warned the acquaintance that it was an antipollution fault. There is no problem in the towing of the car. When I received the abs brain was problematic, sometimes abs fault writing, sometimes writing :) Bidet finally there is a problem in the left signal arm. How long do you think this signal arm is thank you :)
08.05.2020 17:59 # 2
ZP105
Is your car black color
Due to the catalyst due to the catalyst failure, the oxygen sensor is worn during use and if there is no problem with the fuel, you can
Pay attention to abs, it costs money, does it say abs fault in the rain?
If that arm is making a chassis, it can give a lot of breakdowns. Does the car light up itself?
08.05.2020 17:59 # 3
tilbe307
Good luck my teacher will not do anything from lpg.
08.05.2020 17:59 # 4
muammer91
Yes, my teacher is black. It has nothing to do with the rain. It flashes according to its head. ABS :) Yes, when the signal arm turns on the headlight when the headlight burns itself, the horn does not work. Thank you tilbe307 yeah, as I said yesterday, it went out on its own and burned again :)
