Antipolituon fault error help
08.05.2020 21:11 # 1
Numan06
Hello friends, I just joined you. I live in Ankara last week, I bought a 2004 model 1.6 110hp xs 150km gasoline vehicle. No lpg ..
The problem was that the first day I bought the engine malfunction light was on, I looked at the computer, it was giving the catalyst malfunction. In the first run, the helix runs unevenly in the mornings, like a diesel engine, it will recover after 5-10 minutes, but there are occasional unstable conditions. Meanwhile, white steam and water drops come from the exhaust of the vehicle, as if it smells of raw oil.
Where do you think the problem might be ...
08.05.2020 21:11 # 2
Goksu
exhaust manifold catlak was the same problem in me was working like diesel was 3 months then i gave the same error to me manifold casting divided into 3 in our cars manifold casting it could be like that imageag.com/i/74603ea2482 Goksu 2019-03-25 03:54:31
08.05.2020 21:11 # 3
ismailkaya
You connected it to the device and learned where the problem originated.
we cannot know exactly where the problem is caused, just a few of the possible ones below.
1- Defective Oxygen Sensors, especially the upper sensor cables are breaking from the temperature over time. 2- Faulty Spark Plugs
3- Faulty Ignition
4 Faulty Injectors
5- Defective Air Flow Meter
6- Plugged Catalytic Convector
7- There may be reasons like General Vehicle Maintenance Disruption
I guess not using it at high speed is blocking the catalyst. In order to remove the soot and dirt required to use at high speed once in a while from the converter
